Author Topic: Are Seimitsu buttons a good alternative to Sanwa?  (Read 1755 times)
fantoboy
  • Last login:May 24, 2017, 02:02:13 pm
  • I'm a mushroom cloud layin' motha fu($@!
« on: July 09, 2014, 10:15:42 pm »
I have a 1/2" thick control panel, which is too thick for the Sanwa screw buttons.  I was going to drill out the bottom, but I see Seimitsu makes a longer screw button.  Are they pretty comparable to Sanwa buttons?
http://www.focusattack.com/seimitsu-ps-14-gn-screwbutton-white/
amendonz
Re: Are Seimitsu buttons a good alternative to Sanwa?
« Reply #1 on: July 10, 2014, 12:01:46 am »
yes, they are very similar really, just slightly flatter and less shiny finish. feel fairly close in terms of how hard you have to push them to activate the switch
  • Last login:October 20, 2023, 11:39:06 pm
« Reply #2 on: July 10, 2014, 12:26:23 am »
I have used them and they are great.  Especially when paired with button silencers from FocusAttack.com  :applaud:
DeLuSioNaL29
  • Last login:May 05, 2024, 08:59:50 am
« Reply #3 on: July 10, 2014, 10:00:57 am »
They are good buttons, but I'm not so sure they will work with 1/2" either.
I use the Seimitsu KN buttons which look to be about the same length.  They are in a 1/2" panel, but it's routed out.  I don't think I even considered trying it in the full thickness panel.  I'm pretty sure it won't work, but I'll check when I get home.
I'd contact focusattack and inquire before ordering.
shponglefan
« Reply #4 on: July 10, 2014, 12:22:57 pm »
IMHO Seimitsu buttons are better than Sanwa.
  • Last login:Today at 12:55:42 am
« Reply #5 on: July 10, 2014, 03:01:15 pm »
They will work with 1/2" unless you add plexi on top.
