Author Topic: How to power a Bartop Arcade  (Read 1303 times)
gunit
  • Last login:September 08, 2015, 04:21:06 pm
« on: July 08, 2014, 03:35:22 pm »
Hi guys I have been looking into how you can power a bartop arcade and the majority seem to go down the easier option of including 4 gang extension lead inside the unit. I would like to avoid using plugs and the extension bar so I really could do with some guidance, Please see a rough diagram below:-
Can anyone help explain how I can get the ideal solution ?
EMDB
  • Project RetroCade
Re: How to power a Bartop Arcade
« Reply #1 on: July 08, 2014, 06:19:00 pm »
Like this.
Make sure the BIOS of the PC is set to start on power on. This way you can switch everything on and off using the red mains switch (only power everything down after you shut down the PC with your front end)
gunit
« Reply #2 on: July 09, 2014, 11:59:50 am »
Sorry I have another Question, how can I get my (amp/speakers/12v transformer) from Coaxial power connector to a molex connecter so that I can connect to the psu. I was hoping a coaxial to molex existed but have had no luck.
JDFan
  • Last login:May 21, 2023, 04:07:42 pm
« Reply #3 on: July 09, 2014, 12:41:05 pm »
Why not just splice the 2 wires ( one + one - ) from the transformer plug that goes to the amp to the proper 2 wires from the molex connector ( Ground and +12V) and get rid of the molex connection (since you will already have the plug needed to plug into the AMP that can be used to disconnect if needed so the molex is just adding another connection point to fail.
Or buy one of these type connectors  ( http://www.sourcingmap.com/cctv-camera-video-21-55mm-dc-male-connector-power-cable-plug-adapter-p-45708.html ) to use with the 2 molex wires after cutting them
« Last Edit: July 09, 2014, 12:54:00 pm by JDFan »
EMDB
  • Project RetroCade
« Reply #4 on: July 09, 2014, 03:12:18 pm »
Just cut the wires and use any type of connector (make sure to connect the polarity right !)
gunit
« Reply #5 on: July 10, 2014, 08:49:24 am »
Thanks for all the responses, I have updated my plan:-
What do you think ?
BobA
  • What Me Worry?
« Reply #6 on: July 10, 2014, 09:06:06 am »
Where you show "not sure how to connect"  cut the wires Black is ground and yellow is 12V.
JDFan
« Reply #7 on: July 10, 2014, 11:05:05 am »
This -- also I notice on your PSU it is an older design with a plug that can be used to plug the monitor cord in directly so no need for the splitter on the main cable -- just wire the PSU to the inlet switch and then plug the monitor cable into the plug on the PSU (it is wired so that it would be the same as the splitter (ie. will not effect the output of the PSU as it is a seperate circuit ) and the power going to the monitor will not lower the amperage available as out put from the PSU  saving the cost of the splitter cable ) -- a Side benefit of doing it this way is when the PSU is off the monitor will also be off.
« Last Edit: July 10, 2014, 11:06:37 am by JDFan »
gunit
« Reply #8 on: July 10, 2014, 02:54:22 pm »
I am looking at getting the Corsair CS450M - Power supply. Pic was just an example pic of a psu
