Author Topic: LED power supply  (Read 1361 times)
jaharr01
  • Last login:August 27, 2020, 06:28:16 am
LED power supply
« on: July 05, 2014, 01:33:20 pm »
I ordered these 10 PCS 3W RGB Color High Power LED Light Emitter 4 pins with 20mm Star Base
http://www.ebay.com/itm/161057070124?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
I haven't messed with RGB LEDS before so I have a question. If I use 5 of these it says the maximum voltage is 3.6 per LED I used an LED calculator
DC Forward Voltage (VF): Red: 2.0-2.5Vdc, Green: 3.2-3.6Vdc, Blue: 3.2-3.6Vdc,
DC Forward Current (IF): Red: 400MA/ Green: 350MA/ Blue: 350MA
Solution 2: 1 x 5 array uses 5 LEDs exactly
+12V                   R = 22 ohms
                R = 22 ohms
                R = 22 ohms
                R = 22 ohms
                R = 22 ohms
The wizard says: In solution 2:
•   each 22 ohm resistor dissipates 3520 mW
•   the wizard thinks the power dissipated in your resistors is a concern
•   together, all resistors dissipate 17600 mW
•   together, the diodes dissipate 7200 mW
•   total power dissipated by the array is 24800 mW
•   the array draws current of 2000 mA from the source.
Is this correct,should this work OK?
Jay
« Last Edit: July 05, 2014, 02:04:52 pm by jaharr01 »
  • Last login:Today at 12:55:42 am
Re: LED power supply
« Reply #1 on: July 05, 2014, 02:09:36 pm »
Have you considered using a 5v power supply?
12v - 3.6v = 8.4v drop across the resistor -- 70% of the total energy is wasted/dissipated as heat. (8.4v/12v)
  5v - 3.6v = 1.4v drop across the resistor -- 28% of the total energy is wasted/dissipated as heat. (1.4v/5v)
Using a 5v supply will result in about 16.66% (1.4v/8.4v) of the heat dissipation/power waste required for a 12v circuit -- assuming that you choose resistors that allow the same amount of current to pass.
Also, each channel (red, green, and blue) will need a resistor that keeps it within the voltages you mention in your OP.
3.6v applied to the red channel = very bright for a while followed by a "magic smoke" leak.   :angry:
For 5 RGB LEDs, you need to calculate for 15 channels (5 red, 5 green, and 5 blue), each channel will need a current-limiting resistor that brings the voltage down to a safe level for that color in the LED.
« Last Edit: July 05, 2014, 02:41:27 pm by PL1 »
jaharr01
« Reply #2 on: July 05, 2014, 02:27:41 pm »
Yes I can,I can use a switchable power supply. It also has 5V. Will they be less bright at 5v?
jaharr01
« Reply #3 on: July 05, 2014, 02:34:07 pm »
They are flashers on my pinball build so they need to be bright
« Reply #4 on: July 05, 2014, 02:54:44 pm »
Bright = good.
Overdriven = bad.
Having a larger current-limiting resistor will not make your LEDs brighter.
Picture drinking from a drinking fountain (regular 20-30mA LEDs) vs. chugging from a beer mug (your 350mA+ RGB LEDs) vs. drinking from a fully-open firehose. (your LEDs connected to 5v or 12v *without* current-limiting resistors)
You can't keep up with the firehose, it will overwhelm you unless you put a pressure/flow reducer (current-limiting resistor) inline with the hose.
« Last Edit: July 05, 2014, 03:07:32 pm by PL1 »
« Reply #5 on: July 05, 2014, 03:30:47 pm »
If you use the 12v resistor value (22 ohms) with a 5v input voltage, it will probably be noticably dimmer on your setup.
Run the calculator again to determine the correct resistor for 5v.
12v with a 22 ohm resistor and 5v with the proper resistor will be the same brightness because the calculator is figuring out what value/wattage resistor will provide the maximum desired voltage/current at the LED.
jaharr01
« Reply #6 on: July 05, 2014, 10:14:03 pm »
Solution 0: 1 x 5 array uses 5 LEDs exactly
+5V
+   -|>|-   -/\/\/\-   +   R = 3.9 ohms
The wizard says: In solution 0:
each 3.9 ohm resistor dissipates 624 mW
together, all resistors dissipate 3120 mW
total power dissipated by the array is 10320 mW
I can do it 5v it's not a problem
jaharr01
« Reply #7 on: July 05, 2014, 10:17:56 pm »
And I ran the 5v for 15 channels and it was still 3.9
« Reply #8 on: July 06, 2014, 02:09:39 pm »
If you are getting the same value resistor for red as you're getting for green/blue, you're not entering the proper values into the LED calculator.
3.9 ohm ==> 5v supply, 3.6v LED voltage (blue/green), and 400mA current draw (red) -- this will over-volt the red channels and over-amp the blue/green channels causing the reds to blow quickly and probably the blues/greens, too.
Calculate one group at a time -- channels that need the same voltage/current will use the same value/size resistor.
The values I plugged into the LED calcualtor are highlighted in red in case you want to adjust them.
    Group one -- Red channels: (5 total channels)
Power supply voltage: 5v
LED DC Forward Voltage (VF): Red: 2.0-2.5Vdc
LED DC Forward Current (IF): Red: 400mA
* You will need 6.8 ohm 2 watt resistors.
* Each 6.8 ohm resistor consumes 1088 milliwatt.
* The array draws current of 2000 mA from the source.
    Group two -- Green/Blue channels: (10 total channels)
LED DC Forward Voltage (VF): Green: 3.2-3.6Vdc, Blue: 3.2-3.6Vdc
LED DC Forward Current (IF): Green: 350mA/ Blue: 350mA
* You will need 4.7 ohm 1 watt resistors.
* Each 4.7 ohm resistor consumes 575.75 milliwatt.
* The array draws current of 3500 mA from the source.
The 5v power supply needs to be able to handle a current draw of up to 5.5A (2000 mA + 3500 mA) which corresponds to all channels at full brightness.
5v
 |   /--  Red 1 LED--- 6.8 ohm -- LED controller channel 1
 |---  Green 1 LED--- 4.7 ohm -- LED controller channel 2
 |  \--- Blue 1 LED--- 4.7 ohm -- LED controller channel 3
 |   /--  Red 2 LED--- 6.8 ohm -- LED controller channel 4
 |---  Green 2 LED--- 4.7 ohm -- LED controller channel 5
 |  \--- Blue 2 LED--- 4.7 ohm -- LED controller channel 6
 |   /--  Red 3 LED--- 6.8 ohm -- LED controller channel 7
 |---  Green 3 LED--- 4.7 ohm -- LED controller channel 8
 |  \--- Blue 3 LED--- 4.7 ohm -- LED controller channel 9
etc.
jaharr01
« Reply #9 on: July 06, 2014, 03:35:56 pm »
oh i understand now I ran them all the same.
« Reply #10 on: July 06, 2014, 04:22:21 pm »
Glad to assist.   :cheers:
