Main > Main Forum
How to solve Power On/Off Problem?
Pages: << < (3/3)
Sasquatch!:
--- Quote ---
Here's a link that might be helpful. This was a topic of discussion recently.
http://home.bendcable.com/werstlein/
WOW, that is helpful!  Thanks for the info!
jets:
I was reading thru the faq and cam across this thread. The Quickest and easiest solution I found was the smartstrip power strip found at http://www.bitsltd.net/smartstrip/information.htm
Lilwolf:
the smartstrip (plus the powermite or something... there is a smaller verions for 15 bucks or so) is a GREAT solution.
you have the power button from the computer on the outside of the cab and you press it... when the pc comes up it turns everything else on...
krick:
Check out this thread...
http://forum.arcadecontrols.com/index.php/topic,20611.0.html
Fat_Trucker:
--- Quote ---the smartstrip (plus the powermite or something... there is a smaller verions for 15 bucks or so) is a GREAT solution.
Thats ideal.
I'm doing my first cab and have managed to pull most of the info I need from trawling the FAQ and some other sites. This was the only issue I was anticipating trouble with......solved.
Pages: << < (3/3)
Go to full version
