Author Topic: ARCADE VGA or Scanline Generator SLG3000?  (Read 2417 times)
williamavished
  • Last login:February 02, 2015, 02:02:00 am
  • The best Computer Ever Made A500
« on: June 05, 2014, 01:38:50 am »
Hi iam new here in this forum ;D
I am plan to build arcade machine. And want to put televisions. With ports SCRAT or S-VIDEO.
My question is which one is better in terms of quality of the SLG or ARCADE VGA?
I heard ARCADE VGA not bad. But no matter which monitor you add it, you had problems directions of the screen.
« Last Edit: June 05, 2014, 01:43:32 am by williamavished »
ChanceKJ
Re: ARCADE VGA or Scanline Generator SLG3000?
« Reply #1 on: June 05, 2014, 01:42:26 am »
Neither.
I asked myself that same question once.  Go with one of Crafty's SLG Mini's and some VGA.
http://forum.arcadecontrols.com/index.php/topic,129344.0.html
Just do this and make your life simple. You will not be disappointed.
All this or just go classic CRT and be done with it.
williamavished
« Reply #2 on: June 05, 2014, 01:48:45 am »
Neither.
Thanks men  ;) i will check it out.
« Reply #3 on: June 05, 2014, 04:18:38 am »
For a Scart (RGB) equipped CRT TV, your best option is ArcadeVGA or Soft15khz. Either will give you the same result as a real arcade monitor.
If the TV is not a CRT then there may be better options...
rCadeGaming
  • Last login:December 20, 2023, 09:16:09 pm
  • Just call me Rob!
« Reply #4 on: June 09, 2014, 04:59:57 pm »
Yeah, probably should be made clear that SLG's are only good for LCD/LED/Plasma, etc.
A CRT will be a lot more work to set up, but will give you better looking, authentic video, with no input lag (from the display at least).  Everyone's decision about the display is different based on time, interest, and how picky you are about video quality and lag.  If you do go with a CRT, you'll need either a SCART input, or a component input and a VGA to component transcoder.  There aren't any quality s-video solutions available for MAME right now.
GroovyMAME+CRT_Emudriver is another option on the PC end.  The ArcadeVGA has the advantage of simplicity, but it is not flexible enough for advanced users.  Soft15kHz is obsolete, there's not much reason to get into that instead of CRT_Emudriver.
« Reply #5 on: June 10, 2014, 10:03:11 am »
Thanks, I didn't know about CRT_Emudriver. That said, I still use Soft15khz and it does all I need it to...I do like using old stock versions (& my own builds) of Mame versions however.
