Main > Main Forum
game console
thomas_surles:
--- Quote from: leapinlew on June 01, 2014, 12:11:31 pm ---You may want to test it without that fan to make sure the laptop doesn't overheat under a load.
Since you are building it in a box, was there a reason you couldn't have kept the whole thing together and just extend the power button?
I tested it without the fan.
That was a thought at first. Then I was hoping to reduce the size and the bard was bigger than I hoped. But its out now and I dont see much of a point in putting it back together
nitrogen_widget:
Don't you have a table?
Some sheets can generate a heck of a static shock when you rub up against them wearing certain clothes.
thomas_surles:
--- Quote from: nitrogen_widget on June 01, 2014, 12:47:46 pm ---Don't you have a table?
Thanks for that. I never really considered it. I will be more careful now.
Caparo8bit:
Im making the same thing and im using a HDDVR case
ark_ader:
The first rule in laptop hacking is leave the base in the plastic.
The second rule in laptop having is leave the base in the plastic.
There is no point in separating the parts, as it causes more grief. I learned this the hard way.
