May 07, 2024, 05:37:31 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Video Games
through our link. Thank you!
Forum notices to gmail.com addresses are working. Microsoft addresses are still not.
The NEW Build Your Own Arcade Controls
Main
Main Forum
Advice on case fans
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Advice on case fans (Read 667 times)
bigster
Trade Count:
0
Full Member
Offline
Last login:June 16, 2022, 08:24:40 pm
Advice on case fans
on:
May 31, 2014, 11:01:29 am »
I was planning on drilling holes in my cab today for some case fans. It is a tight fit and I do not want things overheating. I made this drawing (with MS PAINT!!) that seems to make sense. All the hot air rises. 1 fan on the hdd, entry fan blowing on the motherboard and exit fan up top blowing all the hot air out. also the hot air can escape through the small cord hole (about 1.5 inches in diameter). Am I on the right track? I don't want to drill large holes if it is wrong.
Logged
Some questionable things going on in this room with cheetos
Trade Count:
+4
Full Member
Offline
Last login:April 30, 2024, 06:21:28 pm
Re: Advice on case fans
Reply #1 on:
May 31, 2014, 11:47:32 am »
I've had good luck just pushing air in and letting it passively exhaust.
Logged
My Projects -
http://forum.arcadecontrols.com/index.php?topic=49622.0
JDFan
Trade Count:
+1
Full Member
Offline
Last login:May 21, 2023, 04:07:42 pm
I want to build my own arcade controls!
Reply #2 on:
May 31, 2014, 12:31:48 pm »
Looks about right -- though what type of PSU and where is the fan located in it (ie. will it be sucking in the air that the upper fan is also trying to expel or is it pulling air in through the cord hole and expelling it toward the fan out - or is it pushing the air out the bottom of the PSU and back toward the MOBO ?) Depending on how the PSU moves air you will want to try to keep the air flowing in one direction as much as possible for the best results.
Logged
Global Moderator
Trade Count:
+1
Full Member
Offline
Last login:
Today
at 12:55:42 am
Designated spam hunter
Reply #3 on:
May 31, 2014, 02:54:24 pm »
The other thing to consider is the distance between the two fans on the right.
Make sure they are far enough apart that the exhaust from the upper fan isn't pulled in by the lower fan.
Logged
KADE-compatible AVR vendors list
nitrogen_widget
Trade Count:
0
Full Member
Offline
Last login:March 30, 2024, 09:10:09 am
Reply #4 on:
June 02, 2014, 09:26:06 pm »
If it were me, one fan at the bottom, one fan at the top.
Go 5 inch fans.
Bigger fans move more air at slower speeds.
That equals less noise with same cfm as smaller fans. Usually.
Logged
lilshawn
Trade Count:
+3
Full Member
Offline
Last login:
Yesterday
at 08:27:40 pm
I break stuff...then fix it...sometimes
Reply #5 on:
June 02, 2014, 09:49:52 pm »
i usually go in at the front and out at the back or in at the bottom and out at the top. get the flow going.
if the case has strategically placed vents or holes, I have everything push out and allow the case to do the cooling.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Main Forum
Advice on case fans
