Main > Main Forum
how do I remove this jamma monitor from the machine?
Pages: << < (5/5)
Malenko:
--- Quote from: leapinlew on June 01, 2014, 05:52:50 pm ---When is the appropriate time to tell someone not to kill themselves?
Less dangerous to pull a monitor in 1 piece than it is to have newb try to discharge a monitor inside a cab and then try to pull it.
DeLuSioNal29:
I agree Malenko.  Just wanted to make sure someone at least told him, "Be careful, you can get shocked if you touch the wrong part".  That's really what I should have said.  You're right, there was no need to overcomplicate things.
D
ed12:
right
the poster never said they wanted to remove the tube olny..
as a rule and after repairing crt's longer then most have been around
i do discharge...but the poster olny wanted to remove the full thing..
my grammer fall's under to each there own
if u pp want proper grammer noun's and pronoun's then all of u do your self a favour
a=learn to read
b=increase posting size
c=get off of the high horse u are on,it's a long way down trigger
d=learn to spell
e=make sure u do the same,respect is earned not given
ed
CraftyMech:
What do you plan to do with the monitor? Does the tube have any burn?
Working standard res arcade monitors with good tubes don't grow on trees. Please don't junk it if you are planning to replace with an LCD, there might be someone in your area that will take it off your hands, and you'll make a little cash to fund your project.
ed12:
darn good point CraftyMech
 :cheers: :cheers:
ed
Pages: << < (5/5)
Go to full version
