Author Topic: Mame version  (Read 866 times)
Marc_
  • Last login:May 02, 2014, 07:47:14 am
Mame version
« on: May 01, 2014, 06:02:51 pm »
Good evening all,
Eventually getting around to building my cabinet and sat down to sort out the PC that is going to be used, but the problem is I have loads of ROMs but I dont know what version of Mame they run on.
Is there any way at all to find this out or is it as mundane as checking each version to see?
Also are CHD files Mame version specific?
Marc
keilmillerjr
  • Web Developer.
Re: Mame version
« Reply #1 on: May 01, 2014, 06:31:36 pm »
Use this app to check your roms against your mame dat file. It will tell you which are out of date, and let you update them.
http://www.romvault.com
This app is much easier to use than the recommended clrmamelro app. I don't understand it. Whoever built the app needs a lesson in effective communications and gui. It's crazy.
JODY
  • Last login:January 19, 2024, 05:06:29 pm
  • After a long delay...the arcade is underway!
Re: Mame version
« Reply #2 on: May 01, 2014, 08:04:54 pm »
The CHD files have changed between some versions so if your files are old enough, they may not work with the latest version of Mame.
Marc_
Re: Mame version
« Reply #3 on: May 02, 2014, 07:28:13 am »
Thanks for the replies, really appreciate the advice.
Marc
deadmoney5
  • Last login:February 03, 2020, 11:02:02 pm
  • I don't feel tardy
Re: Mame version
« Reply #4 on: May 02, 2014, 04:35:53 pm »
Word..NEVER understood clrmamepro.  I'll have to check out the romvault.
lilshawn
  • Last login:Yesterday at 08:27:40 pm
Re: Mame version
« Reply #5 on: May 02, 2014, 05:16:04 pm »
if your CHD's are out of date by only a version or so, you can often just run chdman.exe with "chdman.exe -update <inputfilename>.chd <outputfilename>.chd" command
if it's more than a few versions out, you might be better just downloading a whole new set verified as working.
