Author Topic: .  (Read 1366 times)
ChanceKJ
« on: April 29, 2014, 08:38:49 pm »
« Last Edit: March 18, 2021, 11:28:06 pm by ChanceKJ »
jdbailey1206
Re: Has anyone used these castors before?
« Reply #1 on: April 29, 2014, 08:59:48 pm »
ChanceKJ
« Reply #2 on: April 29, 2014, 10:19:22 pm »
« Last Edit: March 18, 2021, 11:28:11 pm by ChanceKJ »
ChanceKJ
« Reply #3 on: April 29, 2014, 11:03:55 pm »
« Last Edit: March 18, 2021, 11:28:15 pm by ChanceKJ »
WakiMiko
« Reply #4 on: April 29, 2014, 11:45:31 pm »
I also used them in my project and even wrote a paragraph or two about the wheels, hope this helps: http://forum.arcadecontrols.com/index.php/topic,138556.0.html
Keep in mind that the wheels are not centered in the mounting brackets.
« Last Edit: April 29, 2014, 11:50:26 pm by WakiMiko »
mattgold
  • Tinker 'till it's right...
« Reply #5 on: April 30, 2014, 01:12:23 am »
Where did you procure these casters (and feet) if I may ask?
ChanceKJ
« Reply #6 on: April 30, 2014, 01:24:59 am »
« Last Edit: March 18, 2021, 11:28:21 pm by ChanceKJ »
EMDB
  • Project RetroCade
« Reply #7 on: April 30, 2014, 03:28:07 am »
You won't regret them. Make sure the metal plates are flush with the bottom and back of your cab to be able to tilt your cab. I had to modify mine to tilt it completely.
I also purchased this hande from them to mount in the back plate to be able to tilt the cab to the back. I still have to do the back plate though  :laugh:
ChanceKJ
« Reply #8 on: April 30, 2014, 04:08:21 am »
« Last Edit: March 18, 2021, 11:28:26 pm by ChanceKJ »
Louis Tully
« Reply #9 on: April 30, 2014, 04:12:04 am »
« Last Edit: February 12, 2015, 05:08:16 pm by Louis Tully »
  • Last login:Today at 12:55:42 am
« Reply #10 on: April 30, 2014, 05:40:35 am »
Germany :)
http://www.arcadeshop.de/index.php?cPath=83_90
If you prefer to buy them stateside, see Arcadeemulator.net (Divemaster127's site) or Twisted Quarter.
They also carry leveling legs and cabinet handles.
ChanceKJ
« Reply #11 on: April 30, 2014, 10:40:30 am »
« Last Edit: March 18, 2021, 11:28:35 pm by ChanceKJ »
WakiMiko
« Reply #12 on: April 30, 2014, 03:00:36 pm »
The spacers below my bottom plate are 19mm thick and you need at least that much otherwise the leg levers will be too long. Here is a quick drawing
Everything in mm, widths are to scale, lengths probably aren't  :P
« Last Edit: April 30, 2014, 03:02:32 pm by WakiMiko »
