Arcade Collecting > Merit/JVL Touchscreen
ML-1 discussion thread
mahkeymike:
--- Quote from: pivheng on April 27, 2014, 03:47:54 pm ---I'm really disappointed the ML-1. The machine cost more than $3000+ and yet they use all the cheap hardware, especially the hard drive. They could of add SSD to the ML-1. ML-1 came with Toshiba 320gb 5400RPM and it took more than 6 mins to boot up to the main screen. Some of the new HD game are really lag if you press it too fast. like, Tri Tower II, Tri Castle II, etc. :cry: :cry:
i'm thinking of going back to the RX. :applaud:
I would.
pivheng:
mahkeymike
Here are the JIT debugging message screenshot i took.
pix 1-5 http://postimg.org/image/co3fk8spv/
pix 6-10 http://postimg.org/image/k5tvcbhfv/
mahkeymike:
Can you copy over the "C:/Users/AMI/megatouch/tools" And "C:/Windows/Microsoft.Net" folders?
I could take a look at the files that were called with .Net Reflector and VBReformer.
ed12:
Ken Layton
this is a very bad problem with there new :final: s/w
u MUST USE S/W 4 AND 8 to place it in recovery mode
it will get there and run with no hickup's
mahkeymike
once the harddrive is reged with merit
u cannot get a second copy >for that sa-key-serial#<
which is read out through the up-date >final<
the jit .net error is the server saying thank's but no thank's
as they remove it on there way out
it is akin to windows xp stuff/dos/windows3.1 etc
your walk around is to replace the file's >proul there< in question
ed
pivheng:
--- Quote from: mahkeymike on April 28, 2014, 07:04:03 am ---Can you copy over the "C:/Users/AMI/megatouch/tools" And "C:/Windows/Microsoft.Net" folders?
mahkeymike
what is your email i can send you all the file from the Tool and Microsoft .NetFrame Folders
Ed
I read the ML-1 manual on page 39 Swapping hard drive. it show when a new hard drive is detected on an ML-1 the system will recongnize the new hard drive during boot up and display the SYSTEM RESET MENU. I wonder if the new hard drive is from (MEGATOUCH) ??? ???
http://www.megatouch.com/support/ml-1/ML1_Manual.pdf
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
