Main > Software Forum
Change keyboard config outside of Mame?
Pages: << < (2/2)
Jakobud:
Why the heck haven't the Mame developers made the cfg files editable ascii files that we can open in wordpad??  That would make it so easy to copy stuff around...
Jakobud
Howard_Casto:
our mame developer friends did alot of odd stuff that i don't understand...
like:
putting tabs in the listinfo output so when you parse it you have to go to the trouble of removing them
going to the trouble of saving nvram into text files so high scores, and credits can be saved, but not allowing you to easily edit any of this data externally
making the default button 2 left alt, which no pc game in it's right mind uses because it's a dedicated windows key.
making all outputted lists arrange by date added by default, which is useful for them but makes the lists rather useless to anyone else without re-arranging them
ok, ok I'm done,but actually I'm just nit-picking........  But since you went there I thought I'd go to.  :D
Lilwolf:
Somebody below posted the file format if you want... but why?
The whole point in doing this would be so you could configure a game once and have all games that are similar to this work right?
Well, do that by copying the default.cfg and only setting the defaults.  Then keep track of your files.  If you don't want to keep track of the files, you could create the default.cfg.  But why generate a cfg file for each game?
With a little figuring out of the variables you have in hand (number of players, number of buttons, input types, ect) you can come up with an algorythm that will allow you to copy the defaults around for you.
What I use in jfront (about, don't remember the order)
1) custom <so I could create on called MK and set it in each MK game>
2) players_input_buttons (this was primarily to switch the punch and kick buttons on SF games in one shot)
3) players_input (I don't use it, but I added it
4) players (So 4 player games use the joystick on the far left, all 1,2,3 player games use the middle ones)
5) inputs (so all 4 way games can have up notleft notright setup)
This takes care of about 95% of the games with only a few configuration files I copy around.
so when I start a game, I check to see if these files exist
<input_property_value>.cfg
2p_8way_6b.cfg
2p_8way.cfg
2p.cfg
8way.cfg
I first check in the selected control panel directory, then a default directory for each until I find one.  I copy it to cfg/default.cfg when starting and copy it back when I'm done.
I considered adding the config myself, but then I just figured that I would have to create screens to do it, would be a pain in the arshe to configure it since it wouldn't be ingame.... and I didn't want to spend any more time on it.  ;D
Pages: << < (2/2)
Go to full version
