Author Topic: Speaker Sound Controls  (Read 1259 times)
MamedInCanada
  • Last login:February 02, 2016, 06:23:09 am
  • Still Learning...
« on: April 11, 2014, 09:12:55 pm »
I have a Logitech 5.1 Speaker System, the volume control is on one of the speakers. I would like to put the system in my MAME cabinet, but control the volume by a knob say in the center or left side of the speaker grill.
Any ideas?
I'm lost, can I extend the volume control to a potentmeter? Dismantle speaker and put circuit board behind grill? Can I buy a volume control and have the speaker set connect to it then to computer?
Slippyblade
  • Last login:November 16, 2023, 11:39:51 am
Re: Speaker Sound Controls
« Reply #1 on: April 11, 2014, 09:44:16 pm »
Take apart the speaker with the volume.  Odds are, it's already a potentiometer that can be unsoldered and have extension wires soldered to it to allow you to position where ever you want.
  • Last login:May 05, 2024, 08:59:50 am
« Reply #2 on: April 12, 2014, 09:32:33 am »
Simplest way is to use an inline volume control like this between the computer and the speaker amp.
http://www.ebay.com/itm/BRAND-NEW-Universal-Car-Amplifier-Bass-RCA-Level-Volume-Control-Knob-AALC-LC-1-/400574803642?pt=LH_DefaultDomain_0&hash=item5d441e6eba
You can also just hack a potentiometer into the audio cable (before the amp).
There are instructions on here somewhere if you search for them.
For the price, I'd just buy the premade thing.
Going this route, you just leave the original speaker control turned on and turned up.
If everything in your cab is controlled by a smart power strip, that will cut power to the speakers when the pc is turned off.
« Last Edit: April 12, 2014, 09:34:15 am by BadMouth »
TheOne
  • Last login:January 18, 2016, 08:48:32 am
« Reply #3 on: April 12, 2014, 01:27:51 pm »
...or you can just use a software controlled volume program and assign a "shift" button for volume up and down.
  • Last login:October 20, 2023, 11:39:06 pm
« Reply #4 on: April 12, 2014, 06:34:17 pm »
CabVol is a good one written by the forum user DaOldMan. You can use the joystick and a hot key to lower/raise the volume.
TheOne
« Reply #5 on: April 13, 2014, 08:56:14 am »
Yep, that's the one I use.
thomas_surles
  • Last login:June 19, 2023, 07:20:00 pm
« Reply #6 on: April 13, 2014, 11:34:33 pm »
I took apart the speaker and made a simple extention to the knob.
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
« Reply #7 on: April 15, 2014, 08:27:49 am »
Just throwing in my 2c...
Similar to CabVol, you can use buttons if you're using a Minipac and assign +/-.
If you're set on using a pot, then as has been said, just extend the wire.
MamedInCanada
  • Still Learning...
« Reply #8 on: April 15, 2014, 01:24:26 pm »
Thanks for all the great options...I'm gonna open them up this weekend and see what I can do.
Thanks again!!!
MamedInCanada
  • Still Learning...
« Reply #9 on: June 07, 2014, 07:32:24 pm »
UPDATE:
I purchased the Logitech X-540 since it had a seperate control, removed speakers for front, center, and rear; filled in the old speaker holes, paint, drilled new holes, mounted the controller in the center for easy access, looks good...and thanks again for the ideas!
