Main > Main Forum
how is your joystick mounted ?
shayvidas:
--- Quote from: EMDB on March 11, 2014, 09:13:25 am ---The only way to mount a joystick without using a router is to under mount (see FAQ) and use a longer shaft...
if for a second i'd leave.. the "get a longer shaft" joke aside..
where do i really get a longer shaft for my joystick ?
pbj:
Do you even google, bro?
http://www.paradisearcadeshop.com/hollow-shafts/421-sanwa-jlf-stainless-steel-hollow-joystick-shaft.html
PL1:
--- Quote from: shayvidas on March 11, 2014, 02:50:23 pm ---where do i really get a longer shaft for my joystick ?
Helps when you mention which joystick you're using. ::)
There are other ways, but they are less commonly used.
Slagcoin shows a layering method here that you could achieve without a router.
severdhed:
undermounted in a recessed area to raise the height of the stick, bolted in from bottom into flush mounted T-nuts
spend $40, get a cheap router and bits from harbor freight.. they are not great for big jobs, but more than enough for recessing joyticks and routing tmolding slots.
http://www.harborfreight.com/1-4-quarter-inch-trim-router-44914.html#.UyC_E_ldUU4
http://www.harborfreight.com/5-piece-m2-hss-router-bit-set-43695.html#.UyDIUPldUU4
eds1275:
I undermounted my joysticks and regretted it. But the other day I put some washers on the joystick shaft to eat up some of the real estate of the threads, and that $0.10 idea really saved me from cutting a new panel.
