Author Topic: UltraStik 360 - Why isn't output mode working? (re: IPAC)  (Read 1386 times)
sofakng
  • Last login:February 18, 2021, 04:19:21 pm
« on: February 15, 2014, 10:11:29 am »
I've installed two UltraStik 360's into my cabinet and the USB-mode works fine and Windows detects the joysticks.
However, I've attached the 10-pin header to the joystick, and then connected the following wires:
USB = (connected to PC)
BLACK = IPAC GND
ORANGE = P2 - Right
YELLOW = P2 - Left
GREEN = P2 - Up
RED = P2 - Down
However, the IPAC doesn't detect any inputs from the joystick.  Do I have to enable the "Output Mode" of the U360 joystick somehow?
I am also wondering if I could daisy-chain the four direction wires to my dedicated 4-way joystick (so both joysticks could be used in digital/keyboard mode if I wanted)
« Last Edit: February 15, 2014, 10:13:34 am by sofakng »
mgb
  • Last login:February 21, 2024, 06:18:13 pm
  • North East, US
Re: UltraStik 360 - Why isn't output mode working? (re: IPAC)
« Reply #1 on: February 15, 2014, 10:46:25 am »
Do you have 5 volts wired to it.
sofakng
« Reply #2 on: February 15, 2014, 12:28:32 pm »
I don't think it's needed because it's powered via USB, right?
mgb
  • North East, US
« Reply #3 on: February 15, 2014, 01:20:39 pm »
I may be wrong, as I've never used one but I believe you will need to wire up 5 volts to the output wiring harness.
EMDB
  • Project RetroCade
« Reply #4 on: February 15, 2014, 02:22:46 pm »
Output mode is autodetected. You don't need 5V if connected to USB. I use my U360 this way without any problem.
mgb
  • North East, US
« Reply #5 on: February 15, 2014, 03:12:24 pm »
Ok, then I stand corrected.
thanks for the clarification.
Sofakng, have you tried emailing Andy at Ultimarc. He's very helpful and quick in solutions with issues regarding his equipment.
