Author Topic: Folding Bartop with manual rotating display design  (Read 2547 times)
Draco_Elessar
  • Last login:May 05, 2018, 12:40:02 pm
  • Way too curious for my own good.
« on: February 12, 2014, 06:17:13 pm »
I have a design for my first bartop/major woodworking project and would like some advice/input on the design. The dimensions are about 27" x 21" x 14". The monitor will be rotated manually from the right side, when it gets into position it will be held in place by neodymium magnet bars. The rotating wheel and notebook with be mounted on a rotating monitor mount. I'm think of paint the plexiglass black for a bezel. At the moment it does not have a theme.
Here it is with a modular control panel (held in place by six neodymium magnets.) So I can use the control panel with my NESputer.
Draco
« Last Edit: February 12, 2014, 10:50:44 pm by Draco_Elessar »
Ginsu Victim
  • Comanche, OK -- USA
Re: Folding Bartop with manual rotating display design
« Reply #1 on: February 12, 2014, 07:12:49 pm »
None of your pictures are loading.
Corrected.
« Last Edit: February 13, 2014, 09:53:16 am by Ginsu Victim »
ark_ader
  • I glow in the dark.
« Reply #2 on: February 12, 2014, 07:46:40 pm »
Magnets, motors and laptop.
Looking forward to this.  :applaud:
Ginsu Victim
« Reply #3 on: February 12, 2014, 08:39:18 pm »
I think the magnets erased all the photos.
Resurrected...
« Last Edit: February 13, 2014, 09:53:47 am by Ginsu Victim »
Draco_Elessar
« Reply #4 on: February 12, 2014, 10:53:50 pm »
Magnets taken out of shopping cart, pictures should be fixed.
DaveMMR
    • TeeVee Games
« Reply #5 on: February 12, 2014, 11:34:58 pm »
Interesting, different and definitely ambitious. Some things to consider though.
1. If it's a manual rotating monitor on a bartop, can you not do something where you can just quickly pull it out, re-orient and put it back in*? A few projects back in the stone age had the "rotating mechanism sticking out the side" setup and it always looked really, really awkward. It was something new back then but now it seems like there are better solutions.
2. Why does it even need to fold, if I may ask? It seems like the idea of folding it is neat but it makes the depth and lines a little kooky (ex. the excess space in front on the controller.)  I constructively criticism without a better solution I admit but if storing a bartop is a concern, then maybe just make a control panel separate from the body that can store neatly inside of it or something similar.
Good luck!
*"That's what she said."
  • Last login:April 28, 2024, 12:59:28 pm
« Reply #6 on: February 13, 2014, 12:10:59 am »
Is there enough clearence there for the joystick?
ark_ader
« Reply #7 on: February 13, 2014, 12:45:38 am »
Any chance to ditch the CP and add a second LCD for pinball?  CP on the nub of the cabinet?
« Last Edit: February 13, 2014, 01:24:43 am by ark_ader »
Draco_Elessar
« Reply #8 on: February 17, 2014, 01:24:04 pm »
Good luck!
I thought of using a hinge on the side, where one could open, rotate and close, but I didn't really like that idea. I thought of putting in a small motor but I don't think that would work with a notebook power supply. Are there any other solutions that might work?
Folding just for space (it fits on my breakfast bar I don't use) and for easy transport. I could put a trackball or spinner to take up space so that the control panel doesn't look so large. I would like to play DOT...
There should be. When I build it :dunno might have to make a modification.
Interesting idea, the control panel is large enough to fit a monitor, I'm more for shooters, and fighting games than pinball.
monkeychunkuk
« Reply #9 on: April 27, 2014, 08:00:57 am »
I had a similar idea for a "bespoke" square case that would fold down when not in use and be the sort of thing you found say maybe in executive office with brass etc
Can't wait to see the final thing all the best
Draco_Elessar
« Reply #10 on: May 02, 2014, 10:21:38 am »
This project got scraped. I have something a bit different in mind, that's not a bartop.
Attached are the CNC plans for the bartop if anyone wants them.
« Last Edit: May 02, 2014, 10:24:35 am by Draco_Elessar »
monkeychunkuk
« Reply #11 on: May 06, 2014, 02:57:32 pm »
Cheers I may modifi them to suit my plans
« Reply #12 on: May 06, 2014, 04:57:20 pm »
Oh man, Bender's Benderama was one of my favourite bartops.  Have a read of his project thread, perhaps that'll help you with some of your questions:
http://forum.arcadecontrols.com/index.php/topic,84113.0.html
LOL, i completely forgot about Bender's Sightings in the wild thread:
http://forum.arcadecontrols.com/index.php/topic,95950.0.html
edit:
Durp, nevermind then. :lol
Draco_Elessar
« Reply #13 on: May 07, 2014, 08:04:29 am »
Good luck with the build!
