Main > Software Forum
Can someone recommend a good universal frontend ..
Pages: << < (2/2)
Howard_Casto:
I don't think your idea will work unless you use the emu itself to select the game.... here's why
if you launch via a bat file then the fe can't pass the game name to the emulator.
Oh and of course check out my fe... Raging Dragon
It is "hard-coded" as you put it, but there's a reason for that.
Do you see any other fe's that support the games mine does?  No, that's because these emu's require special care that must be integrated into the code.  (Not for long though... check out my morg thread)
Also you can add any command-line based emu, by simply pointing it to one of the rom paths and adding any non-mame games to the gamelist.  It will also run any exe, bat, ect in the custom list.
Pages: << < (2/2)
Go to full version
