Main > Project Announcements
Blip - 100% complete - Updated the Control panel
<< < (3/46) > >>
Monkeyvoodoo:
--- Quote from: Le Chuck on January 21, 2014, 06:46:45 pm ---Some much for my "Bleep" theme  :duckhunt
Same for my Bloop theme
yotsuya:
I'm still on for "Blap!"
Vigo:
Blip, Blip, BLAM!
I'M NOT YOUR FRIEND
markc74:
Bah. Now I think I may have inadvertently got the idea from Saints book!
I'll be tv decasing this weekend so I should be able to confirm the profile of the cabinet then. Assuming I'm not staggering about dazedly with young Einstein hair anyway.  :afro:
markc74:
Just a small update as I’ve actually started something now.
The profile of the cabinet is quite shallow and I was a little worried that the TV wouldn’t fit so I’ve started by decasing the TV and putting it into a frame – then I could see if I need to change the plans at all.
Did all the usual – discharged with a screwdriver/croc clip combo and took a ton of photos to make sure I knew where everything went.
Quickly realised that even without the frame (which was pretty heavy) a 25” tube still weighs a decent amount so had to be very careful moving it around and into place.
I’d estimated this to take about 5 hours. In the end it took 10 which I have a feeling is going to be the norm for this build!
Turns out that it will fit ok but I’m adding another inch on the back anyway just to give me a bit of leeway and allow more air to circulate just in case.
Next job will be either the sides or the speaker panel – depends on the weather at the weekend and if it’s too cold to be outside or not!
Navigation
Message Index
Next page
Previous page
Go to full version
