Main > Main Forum
Same ground, different voltages?
Nephasth:
A live wire is perfectly safe to touch... As long as you are isolated from ground. :P
PL1:
--- Quote from: Nephasth on January 24, 2014, 11:45:17 pm ---A live wire is perfectly safe to touch... As long as you are isolated from ground. :P
Mythbusters rules apply here:
Don't try this at home, kids. We're what you call 'experts'. ;D
lilshawn:
if it weren't for the people who do stuff at home, we wouldn't have what you call "dumbasses".
MTPPC:
All your dc ground circuits should be tied together. Then tied to the ground planes in the cabinet. Then tied to the green wire on your power cord and plugged into the ground hole in your 110vac socket. This way, when you touch your game with static from walking across the carpet, all your ICs are protected. You'll also notice that your computer case is grounded through the ground post in your AC plug. Most electrical weirdness is caused by poor grounding.
the_gamer:
--- Quote from: matsadona on January 17, 2014, 02:47:08 am ---The potential difference between two points can be illustrated like this:
It's more like how many people/electrons are on the level but I am not that good at explaining :(
