Main > Monitor/Video Forum
GBS-8100 Power options
Pages: << < (2/4) > >>
ed12:
from what i have read it goes >the settings< to flash/sd ram
so they should auto save
olny way to find out is to run it,do the menu thing
save,remove power..wait about 3 mins
power back up and see if it saved them..if so no need for a bat
if not then we will need to find where to tag 1
as i stated mine will not be here for 10 days yet
ed
bimm25e:
My on screen display has very very limited options
H size
v size
brightness
contrast
hue
saturation
sharpness
"menu background" (which puts black bars behind the menu options - very dumb feature)
and the last one is something like "twitch" or "jitter" can't remember what it was
definitely no "save" option
ed12:
well an easy test is to set the horz freq and vert freq lower by a tad lets say 4#'s
write them down so u can rember them
then once u exit
power unit down
and wait 3 mins
then plug it back in and see if the values still match ?
if they do then u know it is auto saving,if not then it means u will need to tag a bat in
ed
ed12:
ok i was reading over at hackaday
they used this same board..btw it is what turned me onto it
here is some of it
>The only way would be to use video downscaling. This part was hard to solve. We knew we had to downscale our 31Khz VGA signals to 15Khz RGB lines and this is no easy task, it requires powerful video algorithms and heavy processing using dedicated chips. Professional equipments to do this job usually cost hundreds of Euros (or more).
So we though we’d go through the old underground forums and dedicated pages for arcade parts in the hunt for a solution. And we found it.
Our pick is the GBS 8100. This beautiful piece of hardware takes VGA input at 31Khz, downscales the video and is able to output it at 15Khz over RGBS pins (which can be connected directly to the arcade CRT board, cable included), VGA db9, RCA composite video or S-Video. Furthermore it has an OSD menu system and you can calibrate brightness, contrast, video offsets and other details. Requires 5V to operate. And it costs approximately $30.
>link
http://hackaday.com/2012/12/17/using-arcade-monitors-with-the-raspberry-pi/
come down to the part about using a rasberry pi..follow the gbs-8100 link
ed
bimm25e:
Yeah I saw that article but there wasn't too much info there worth reading IMO.
My problem is a little unique in that I have the GBS-8100 in a switching cabinet... so I need to adjust the device to match the other source (a NAOMI) in my cabinet.
The guys who made the raspberry pi arcade had the luxury of adjusting their chassis to the board's defaults they probably don't have to fiddle with the board's defaults at all.
I can get the board matched to the NAOMI but when I cut power, even for a split second, I lose my settings in the device.
For the time being I'm going to just leave the PC/GBS-8100 powered on constantly.  I don't like it but that's the plan for now.
IF you end up with a battery-save solution PLEASE post on the forum.
Go to full version
