Author Topic: Spray Painting Acrylic  (Read 2305 times)
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
« on: December 16, 2013, 08:43:37 am »
Ok, I"m nearing completion of my cab...one of the last phase is the painting of the acrylic that's over the monitor.  Out of curiousity does it matter if the paint be on the outside or the inside?  Gloss or flat/matte?
Richardgregory
Re: Spray Painting Acrylic
« Reply #1 on: December 16, 2013, 09:05:34 am »
Ooops, a search just came up on this subject - some say sand it with 220 grit sandpaper??????
« Reply #2 on: December 16, 2013, 10:52:00 am »
I'd mask off the part you don't want spraied, on the INSIDE of the plex, then hit it with a coat or two of good quality black. I don't think you'll want to sand, since the sand marks will show through, and you definitely don't want to prime.
Now, if you do decide to paint the OUTSIDE of the plex, it's a whole different story. In that case, i'd sand AND prime, but I suspect you'll get much better results painting the inside.
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #3 on: December 16, 2013, 03:16:23 pm »
Paint the inside.  Use a QUALITY painters tape for blocking out the monitor.  hit it with at least 4 layers of paint.  I've used Matte and Semi-Gloss/Gloss and Gloss always comes off feeling plastic/sticky.  Matte feels like I could scratch it away with my finger.  Both look fine at the end of the day on the other side of the glass IMO.
Richardgregory
« Reply #4 on: December 16, 2013, 03:46:23 pm »
Ok thanks...tape like that Frog Tape brand I guess....
jdbailey1206
« Reply #5 on: December 17, 2013, 08:57:01 am »
Any good masking tape will suffice.  You just want something that wont bleed through the tape.  Apply enough pressure so that it won't bleed around the edges and wait until it is completely dry to remove the tape.
keilmillerjr
  • Web Developer.
« Reply #6 on: December 17, 2013, 02:52:11 pm »
Krypton fusion is a spray paint meant specifically for use with plastics, and without he need for a primer. If you spray the back side of the plastic with their gloss black, it will look like the glass bezel on an iphone or ipad from the front. ;)
Garza
  • Last login:July 09, 2015, 10:53:29 am
« Reply #7 on: December 17, 2013, 04:21:05 pm »
Really Really make sure to clean it very good! I found out the hard way without cleaning and double cleaning before paint you will run into problems on adherence. Trust me!  :angry:
kiwasabi
  • Last login:September 28, 2014, 12:14:51 pm
« Reply #8 on: December 17, 2013, 09:44:55 pm »
You can actually have artwork printed directly on plexi if you'd be interested in that. That's what I did.
thehammer12
  • Last login:October 24, 2021, 01:46:34 pm
  • Arcade Breaking Specialist
« Reply #9 on: December 18, 2013, 12:09:54 am »
I just did mine with Rustoleums painters touch 2x (flat black paint + primer)
4-5 light coats and it came out AMAZING, and I didnt sand it at all.
jdbailey1206
« Reply #10 on: December 18, 2013, 08:21:53 am »
Or have it printed and apply it just like you would side and control panel art.
zanna5910
  • Last login:January 28, 2023, 02:43:41 pm
« Reply #11 on: December 18, 2013, 11:19:16 am »
Do we really need a new thread for "has anyone spray painted a bezel" and "what do you spray paint a bezel with?" ??????
You should use this: http://forum.arcadecontrols.com/index.php?action=search2&search=spraypaint%20bezel
jdbailey1206
« Reply #12 on: December 18, 2013, 11:39:26 am »
zanna5910
« Reply #13 on: December 18, 2013, 12:01:05 pm »
Aww, guess its just me then.
Tough love is still love.
thehammer12
« Reply #14 on: December 20, 2013, 01:37:49 pm »
Wow what did I miss here haha.
kiwasabi
« Reply #15 on: December 21, 2013, 03:52:33 am »
Actually, as a follow-up to this... the colors turned out WAY more vibrant when printed on backlit material (which is white) than on clear decals.
Anyway, not sure what the OP decided to go with but if you want an all black bezel it's also really easy to just cut some poster/mattte board. Just make sure it has a black core so you don't have to go over it with a sharpie.
