Author Topic: Painting acrylic glass for the monitor  (Read 1248 times)
thehammer12
  • Last login:October 24, 2021, 01:46:34 pm
  • Arcade Breaking Specialist
« on: December 06, 2013, 06:14:07 pm »
I got the acrylic cut perfectly for the monitor on my arcade, was taping it off to spray it flat black (as I have read many others here have done) but then I realized that my spray can is the rustoleum painters 2x which is primer and paint.
Is that ok to use? Or just regular flat black without primer.
kahlid74
  • Gaming for a better future!
    • GamersAnon
Re: Painting acrylic glass for the monitor
« Reply #1 on: December 06, 2013, 08:14:10 pm »
It should be fine but I have noticed a big difference between semi-gloss and matte with regard to painted on bezel.  If you have any scrape acrylic around paint on that and see how it looks.  It's really up to you on how it feels.
Also, when using a spray can you may have to do multiple passes.  I usually have to do 3-4 passes before you can't see through it.  Make sure to also use a good painters tape.  Crappy ones bleed and it looks bad :(
thehammer12
« Reply #2 on: December 06, 2013, 08:25:49 pm »
Oh crap, I do have scraps....not sure why I didn't think of that haha.
Yeah I figured I would have to do at least 2-3 passes, but ill make sure to go slow and to check it each time. Thanks
DGP
  • Gamer4Life
    • My Toys...
« Reply #3 on: December 06, 2013, 08:28:29 pm »
As stated do several very light coats until you cannot see through it and use FrogTape.
Jason
Brian74
  • Last login:March 10, 2024, 01:55:58 pm
  • Yep... I built that!!
« Reply #4 on: December 06, 2013, 09:39:02 pm »
I gotta ask, how do you guys get the corners with the tape so straight?
Sent from my SGH-M919 using Tapatalk 2
thehammer12
« Reply #5 on: December 06, 2013, 10:49:42 pm »
Jason
---steaming pile of meadow muffin---, I already used some 3M multi surface tape.  It was like pretty dam pricet, lets hope its worth it.
I over lapped them and then took the razorblade to it very carefully. Its super straight now and looks sweet, I will be painting it tomorrow....wish me luck.
thehammer12
« Reply #6 on: December 08, 2013, 02:10:02 am »
Im on the 3rd coat, hope it turns out well.
« Last Edit: December 08, 2013, 02:11:49 am by thehammer12 »
