Main > Software Forum
(I) Fix(ed)-it Felix Wrapper
<< < (15/29) > >>
Howard_Casto:
See the "delay for resize" option?  Make that higher.  It looks like it's scaling fine but it's moving the window before the game fully loads (and the game moves itself at one point).
mkarabinus:
Newbie here...
This is exactly what i was hoping someone has created.  GREAT WORK!
It runs PERFECTLY!!!!!!
bikeguychicago:
I tried running Fixed it Felix full-screen on an vertically-oriented 1280x1024 LCD with the bezel disabled and found that the screen is still being shifted down and to the right as if the bezel was still being shown. Is there something else I need to do to just get the game to fill the screen?
meyer980:
--- Quote from: bikeguychicago on August 26, 2014, 04:44:18 pm ---I tried running Fixed it Felix full-screen on an vertically-oriented 1280x1024 LCD with the bezel disabled and found that the screen is still being shifted down and to the right as if the bezel was still being shown. Is there something else I need to do to just get the game to fill the screen?
This thread may be of use to you, sounds like a problem a couple others are having. If it is the same issue, it's not Howard's wrapper causing the problem. At this point, nobody seems sure. http://forum.arcadecontrols.com/index.php/topic,140671.0.html
jeffsgames:
--- Quote from: meyer980 on August 26, 2014, 05:35:51 pm ---
That's the exact problem I'm having (see other thread).  Howard has an idea that might "fix" the issue that he's going to look into.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
