Author Topic: Setup 12v coin mech.  (Read 1304 times)
Binkles
  • Last login:May 05, 2017, 10:41:45 am
« on: November 18, 2013, 04:35:48 am »
Ok got a coin mech, 12v sucker.
Needs a zender (sp) diode to connect to the ipac2. How has anyone wired this? Can someone please photo theirs where it connects from a psu, through the diode, and then to the ipac.
Please this is starting to really frustrate me.
I've also wired up power, but it doesn't seem to accept any coins (not connected to ipac).
bluemini17
  • Last login:June 06, 2014, 10:26:11 am
    • My Youtube Channel
Re: Setup 12v coin mech.
« Reply #1 on: November 18, 2013, 04:59:41 am »
I made a video years ago for a mars coin mech. prob not that helpfull but worth a look maybe
  • Last login:Today at 12:55:42 am
« Reply #2 on: November 18, 2013, 05:27:20 am »
To program the mech, check out the video here.
Next, click HERE for a post by dgame that has a wiring diagram showing the zener diode between the coin signal line (it then connects to the IPac coin input) and ground.
Look just above the text on the left side and you will see a rectangle with a band -- that's the diode..
The band on the diode is toward the coin signal line. (scroll down to my post in the linked thread above for more details and a related photo)
Binkles
« Reply #3 on: November 18, 2013, 06:17:17 am »
Does the coin mech have a led to say whether it's connected?
Looking for a live example of how people have wired them.
Sorry.
Seen the video, but unsure whether it's even working, or not, I can't seem to tell.
If I have it wired to just the power supply, how can I test to make sure it's working, or juiced even?
michelevit
  • Last login:February 05, 2019, 01:46:18 pm
« Reply #4 on: November 19, 2013, 10:29:53 am »
Hook up the output to a voltmeter. It should trigger 12vdc if working properly.
lilshawn
  • Last login:Yesterday at 08:27:40 pm
« Reply #5 on: November 19, 2013, 05:48:03 pm »
these like most coin mechs, switch the coin signal wire to GROUND if a coin is accepted. (IE goes LOW)
if you tag of the +12 volts you are feeding the mech with and apply the +12 volts to the one end of a 12 volt bulb and connect the other end of the bulb to the coin line...every time a coin is accepted the light will flash.
the mechanism basically is a switch to ground.  :dunno
