Author Topic: Good Video Card soft 15khz  (Read 2388 times)
bimm25e
  • Last login:May 01, 2024, 02:21:05 pm
« on: November 16, 2013, 03:27:02 pm »
Looking for a  product recommendation, my current nvidia card doesn't support soft 15khz so I have to :( BUY :( another one.
PC has a E8500 Core 2 duo processor
and
I realllllyyyyyyyy want to be able to emulate Gauntlet Legends and dreamcast/gamecube
Any opinions on good cards would be appreciated.
« Last Edit: November 17, 2013, 09:57:13 am by bimm25e »
DGP
  • Gamer4Life
    • My Toys...
Re: Good Video Card soft 15khz
« Reply #1 on: November 16, 2013, 09:46:24 pm »
Radeon 4890 is said to be the most powerful out of the box that supports 15khz.
Jason
bimm25e
« Reply #2 on: November 17, 2013, 09:56:56 am »
Jason
do I need a specific manufacturer?
DGP
  • Gamer4Life
    • My Toys...
« Reply #3 on: November 17, 2013, 06:47:59 pm »
AFAIK any of them should work.
Jason
bimm25e
« Reply #4 on: November 18, 2013, 12:06:00 pm »
that card doesnt seem to be compatible with DX11  are any of the cards on the list going to work with soft 15khz AND DirectX11?
  • Last login:February 19, 2024, 12:40:25 pm
« Reply #5 on: November 18, 2013, 12:41:24 pm »
http://community.arcadeinfo.de/showthread.php?7925-Getestete-Grafikkarten
Have you checked here?
Also you might hit up Rob or Calamity in the monitor or groovymame forums.
DGP
  • Gamer4Life
    • My Toys...
« Reply #6 on: November 18, 2013, 05:08:54 pm »
I don't think there is anything that is both 15khz and DX11 (but I could be wrong ??? ).
Jason
rCadeGaming
  • Last login:December 20, 2023, 09:16:09 pm
  • Just call me Rob!
« Reply #7 on: November 19, 2013, 06:03:04 pm »
As long as you're getting a new card, you should switch to CRT_Emudriver.
Soft15kHz is really not the best option anymore.
First of all, it's silly to use a real CRT and not use GroovyMAME, and that works hand in hand with CRT_Emudriver.  GM can generate resolutions on the fly to keep everything native res (and native refresh, very important), saving you a lot of work; and it has a lot of other important features for native res even if you don't use the auto-generation.
Even if not using GM, tweaking your resolutions in Soft15kHz requires editing the text modelines by hand (super tedious), or using Powerstrip.  Powerstrip was not really designed for this application, it's very cumbersome, and does not even fit on the screen in lower resolutions.  CRT_Emudriver includes ArcadeOSD, which was purposely designed for this, is just as powerful if not more so, more flexible, and much easier to use.
Making the change only takes a couple of minutes once you have the right graphics card (which can be dirt cheap).  I started with Soft15kHz, and resisted make the change because I had some GeForce cards on hand (only compatible with Soft15kHz).  When I finally switched over to CRT_Emudriver, I was really kicking myself for not doing it sooner.
« Last Edit: November 19, 2013, 06:05:08 pm by rCadeGaming »
bimm25e
« Reply #8 on: November 19, 2013, 06:41:54 pm »
I appreciate that info very much thank you.  I have to look up more about GroovyMAME, but I actually really like using HyperSpin as a frontend so I just like whatever MAME works and is easy to find, which is MAME for me lol.
rCadeGaming
  • Just call me Rob!
« Reply #9 on: November 19, 2013, 07:10:57 pm »
GroovyMAME works with Hyperspin.
« Reply #10 on: November 19, 2013, 08:31:22 pm »
So is crt emu driver part of groovymame or separate?
And thank you for your many posts on the subject matter, they are extremely helpful
rCadeGaming
  • Just call me Rob!
« Reply #11 on: November 20, 2013, 12:42:29 am »
No prob  :cheers:
CRT_Emudriver is just a driver for Radeon cards that enables custom resolutions, so you can use it with any version of MAME, but GroovyMAME makes the most of its potential.  Both are made by Calamity, and by combining the two GroovyMAME can automatically calculate the best resolution for each game for you on the fly.
