Main > Main Forum
ultrastik 360's not working
drventure:
--- Quote ---okay so last night i plugged them into my HP dv7 laptop on the right side assuming those were 2.0 hubs and same thing occured no communication code 10 cant start then i plugged them into the left side 3.0 high speed i thing and they came up in game controllers
That's very strange. as far as I know, those sticks should work just fine in a USB 1.0 port. Andy will definitely be your best bet for that kind of problem. Maybe there is something up with the firmware on those particular sticks.
GeoMan:
I have 3 x U360 connected to different computers with USB1.1, 2.0 & 3.0
All work fine. So it is not a problem with USB speed. Maybe it is a power problem. I also guess that you tried changing the joystick IDs.
As for firmware updates, you don't have to send them to Andy as you can download the Ultramap utility and do it yourself.
http://ultimarc.com/download.html#ultramap
trendy21:
i think its a power issue I plugged them into my laptop on usb3.0 and upgraded the firmware and assigned id's and tested joysticks and buttons, worked fine and they showed up in game controllers, my mame and game ex settings are enabled for joystick and then plugged them in on my laptop in the 2.0usb and it still said code 10 cant start and wouldn't recognize so I bought a 3.0 adapter to install in the mame cab on the motherboard and we'll see what happens hopefully someone can figure this out I know they work on 1.1 and 2.0 but just not on mine
AndyWarne:
--- Quote from: drventure on November 15, 2013, 10:27:06 am ---
They will definitely not work on an USB 1.0 port. USB 1.1 and higher is OK.
trendy21:
ok i got my stiks working and tested in game controllers with the vantec usb pcie card, still not sure why wont work on any 2.0 but andy has been great help with this and thanks to you guys for the suggestions, now with the game ex front end they and the buttons will work to select game and move up and down but when i select a game and it goes into mame, they stop working and when i exit back out of the game only player 2 joystick works i know you hit tab in the game to configure but isnt there a way to program every console or arcade mode the same instead of setting buttons for thousands of games individually? i will also start a post as i think it involves the front end forum, as for programming the sticks with ultra map i thought i had seen someone had written a program to map in anlog mode for the swithching automatically, again instead of programming individual, the stiks these replaced were sliksticks i think and i see something about gp wiz or raw 49 way in my task manager that is always running with game ex, thanks alot
