Main > Main Forum
who's playing Sega STV games at full speed on their cab?
DGP:
Please do not assume to be the only one that knows and understands the topic at hand.
I understand lag perfectly and have measured it many times with various display technologies, I have run the test and have 'no lag' that can be detected with the simple testing methods.
Shockingly I am also running MAME on AMD hardware (CPU). :o It also runs Blitz and Ridge Racer at full speed, just the normal audio emulation issues.
I am somewhat of a video purist and have been for many years (I am DaGamePimp on AVS forum). ;)
Jason
rCadeGaming:
Exactly what tests did you run, which specific games, and what MAME build.
DGP:
For lack of variables I ran the test that was mentioned in this thread.
I tested Radiant Silvergun & Cotton Boomerang but can test others that I have, did not figure there was a point in testing Die Hard Arcade (hehe).
I am running a custom MAME 143u6.
Obviously the results will vary by display type/tech as well as the connection method used (so there are many variables to consider).
Usually you'll see less lag on a RGB/VGA connection due to less processing unless the display has a GAME/PC mode that disables most of it.
If using an LCD it is best to send the native resolution of the panel.
The most obvious and visible sign of a lag afflicted display is mouse trails (watch the pointer).
Jason
rCadeGaming:
What is your custom build? What I'm getting at is, if it's compiled from the vanilla MAME source, you've done something wrong. I don't think even think ShmupMAME registers zero frames of lag in that test.
DGP:
It's not my compile, it has several tweaks and the main reason I got it a while back was for the hi score saves.
Jason
