Author Topic: Budget Arcade- first build -complete with video demo- $250  (Read 15961 times)
thomas_surles
« on: November 01, 2013, 07:49:34 pm »
I am on a small budget and can only afford a few parts at a time until I get a new job.
so it is not as cool as the others i have seen.
so here we go...
thomas_surles
Re: Budget Arcade- first build
« Reply #1 on: November 01, 2013, 07:58:41 pm »
I know what your thinking, 1/4 inch plywood? well it was the cheapest at lowes. But on the plus side it is very light, but I can't put t molding on it
thomas_surles
« Reply #2 on: November 01, 2013, 08:21:38 pm »
The cp.
thomas_surles
« Reply #3 on: November 01, 2013, 08:24:10 pm »
some progress.
thomas_surles
« Reply #4 on: November 01, 2013, 08:25:33 pm »
and the rest of what I have so far.
Slippyblade
« Reply #5 on: November 01, 2013, 08:36:50 pm »
I feel the budget crunch man.  Good progress so far though, keep it up!
ChanceKJ
« Reply #6 on: November 01, 2013, 08:38:37 pm »
« Last Edit: March 19, 2021, 04:17:22 am by ChanceKJ »
matt4949
« Reply #7 on: November 01, 2013, 08:44:12 pm »
what do you plan on running on the inside a pc? a console? looking good so far.
Slippyblade
« Reply #8 on: November 01, 2013, 09:39:48 pm »
Gerbils.  Lots and lots of gerbils.
thomas_surles
« Reply #9 on: November 01, 2013, 09:45:34 pm »
how is yours any less cool as mine, or any of the other ones on this site for that matter?
This is a brilliant start to something you're gonna love because you built it, t-molding or no t-molding.
I'd be proud to say I built that. For all I know mine will cause grey hair and mysteriously implode before its done......    ;) ;)
Thanks that makes me feel better.
thomas_surles
« Reply #10 on: November 01, 2013, 09:49:05 pm »
I have a laptop with a broken screen that im using right now. its a newish Hp with 8gb of ram and some huge hard drive.
believe it or not I found it beside a dumpster. Was it stolen? I dont know, could be, or they just threw it out because of the broken screen.
Either way, In the dumpster/by the dumpster, thats fair game right?
matt4949
« Reply #11 on: November 01, 2013, 09:52:06 pm »
not everything in the dumpster is up for grabs
« Last Edit: November 01, 2013, 09:54:57 pm by matt4949 »
thomas_surles
« Reply #12 on: November 01, 2013, 09:56:17 pm »
Depends on who is around.  >:D
  • Last login:Today at 03:29:09 am
« Reply #13 on: November 01, 2013, 10:02:58 pm »
Somebody threw away a perfectly good white girl.   >:D
skjerk
  • Last login:February 10, 2016, 05:46:19 pm
  • Been working on my bartop for more than 5 years
« Reply #14 on: November 02, 2013, 04:27:14 am »
Way to go! :applaud:
You know, I've been "working" on mine for the last 5 years, and you are already ahead of me  :banghead:
Will be following you! - Keep it up  ;D
CC-Arcade bartop. Own design, scratch built. Work in progress.
Louis Tully
« Reply #15 on: November 02, 2013, 07:17:21 am »
« Last Edit: February 12, 2015, 03:57:38 pm by Louis Tully »
thomas_surles
« Reply #16 on: November 02, 2013, 12:07:13 pm »
I am considering getting a used trackball mouse rather than an actual trackball.
Has anyone ever tried that?
Something like this.
ChanceKJ
« Reply #17 on: November 02, 2013, 02:01:23 pm »
« Last Edit: March 19, 2021, 04:16:51 am by ChanceKJ »
thomas_surles
« Reply #18 on: November 02, 2013, 02:29:17 pm »
Most of those old trackballs  have removable balls, and very poor rolling resistance. You take one swing with that thing in golden tee and you'll either drive 5 yards with a power swing or skip the ball through your display.
Here:
http://www.aliexpress.com/item/4-5-cm-of-Diameter-Round-Connector-PC-Trackball-mouse-for-arcade-machine-accessories-game-machine/1251402061.html
Or here:
http://www.aliexpress.com/item/2-pcs-of-4-5-cm-of-Diameter-Purple-ball-track-ball-For-Arcade-Game-Machine/921897743.html
Or just go here and shop around:
http://www.aliexpress.com/wholesale?SearchText=Trackball+arcade&catId=&initiative_id=SB_20131102095851
Wow those are nicer and cheaper than the mouse.
thomas_surles
« Reply #19 on: November 02, 2013, 02:31:21 pm »
Did a little more work today.
A combination of wood filler and plaster. Im going to let that harden so I can sand it all down and make the wood smoother.
« Reply #20 on: November 02, 2013, 03:17:44 pm »
You may also want to consider the Sparkfun trackball here.
thomas_surles
« Reply #21 on: November 02, 2013, 04:49:43 pm »
I like that. I might get one if I decide to add a trackball
thomas_surles
« Reply #22 on: November 03, 2013, 03:15:12 pm »
some more sanding and priming.
severdhed
  • RIP Dinosaur Hippo
« Reply #23 on: November 03, 2013, 09:05:14 pm »
That looks good, you should be proud of that.
Sent from my Galaxy S4 using Tapatalk 2
LeedsFan
« Reply #24 on: November 04, 2013, 02:41:28 am »
I personally find plywood to be much nicer to work with than MDF. It's lighter too. It all depends on what grade of plywood is available to buy. I live in the UK and I usually get my wood from B&Q (large DIY superstore). For my most recent project I got plywood from there and they had three grades available. The cheapest was pretty poor. It was very rough on both sides and wasn't suitable for what I wanted to do. But for just £10 extra I was able to get the mid range stuff which is smooth on both sides. Though in some areas it was slightly rough but I could live with it or avoid those small areas. For £another £30 over the cheapest stuff (so double price) they had a cabinet grade ply. This was excellent stuff but I decided to go with the mid to save a little cash.
And why can't you use TMolding? I'm planning on fitting it to my project and I've done it before with plywood with no problems.
thomas_surles
« Reply #25 on: November 04, 2013, 08:38:48 am »
I cant use t molding because it is the thinnest plywood. Its 1/4 inch
thomas_surles
« Reply #26 on: November 05, 2013, 10:59:07 am »
I jusy got a new job so I am about to up the budget a bit.
thomas_surles
« Reply #27 on: March 17, 2014, 09:47:57 pm »
I have not disappeared.
thomas_surles
« Reply #28 on: March 17, 2014, 09:51:08 pm »
I ended up just using a whole 32 oz of woid filler on each side of the cab and sanding it down. It worked very well.
thomas_surles
« Reply #29 on: March 17, 2014, 09:54:03 pm »
Added some usb ports to the front. I just made to holes with a chisel and glued in some female usb extentions.
thomas_surles
« Reply #30 on: March 17, 2014, 09:55:37 pm »
Attached the speaker panel.
thomas_surles
« Reply #31 on: March 17, 2014, 09:57:08 pm »
Another look at the front with 2 new buttons.
thomas_surles
« Reply #32 on: March 17, 2014, 09:58:58 pm »
Also cut a new c p because I screwed up the last one.
thomas_surles
« Reply #33 on: March 17, 2014, 10:01:04 pm »
Stll got a lot of sanding to go.
gabrielmtl
  • Last login:March 18, 2016, 10:19:03 pm
  • This is...
« Reply #34 on: March 17, 2014, 11:37:06 pm »
Looking very good, especially considering your limited budget.
Good luck with the rest
eds1275
  • Last login:March 11, 2026, 11:07:08 am
  • Rock and Roll!
« Reply #35 on: March 19, 2014, 11:55:35 am »
You keep saying 1/4, and I keep thinking... that can't be any thinner than 1/2"... in any case, you can get some pretty amazingly sticky pinstriping for cars in both of those thicknesses that will be a great substitute for t-molding, unless you and your friends constantly pull at the edges. Around here you can get it in your standard rainbow plus chrome, white, and black.
thomas_surles
« Reply #36 on: March 19, 2014, 03:16:32 pm »
Thats actually a really good idea. I was considering painting the trim of it red then taping it off while I do the rest black.
thomas_surles
« Reply #37 on: March 22, 2014, 07:17:39 pm »
Got my conrollers. 2 usb n64 and 2 usb generic ps3 controllers.
The ps3 controllers are for ps1, ps2, gamecube, and most of my pc games.
thomas_surles
« Reply #38 on: March 22, 2014, 07:32:09 pm »
Also cut out some slots for my door hinges so it will mount better.
gabrielmtl
  • This is...
« Reply #39 on: March 22, 2014, 10:53:04 pm »
+1 on the thickness. Gotta be more than 1/4 :)
