Main > Main Forum
Need Help...Which Side Art Location Looks Best?
Pages: << < (3/3)
JDFan:
--- Quote from: kaneda on October 31, 2013, 06:15:53 pm ---
--- Quote from: JDFan on October 31, 2013, 02:30:44 pm ---Yep as others said Far Left but I'd adjust the size to fit better as shown far left below :
Yeah but you can't get that logo to fit like that without stretching it.  That would look dumb, no?
Should be able to adjust it so that it still looks good - what are the dimensions of the side panel ? and are the legs a separate board or is the side panel one piece ?
kaneda:
I believe it's one piece.  It's a dream home arcades pedestal.  They have lots of pictures on their websites.
JDFan:
--- Quote from: kaneda on October 31, 2013, 06:41:22 pm ---I believe it's one piece.  It's a dream home arcades pedestal.  They have lots of pictures on their websites.
Do they list the dimensions by chance ? As it should be fairly easy to modify for example here are a couple versions one 15x8 inches and another 15x6 inches that has been adjusted : I uploaded .jpg format since .png is almost 5MB each so too big for this forum but if you want a png version to avoid the compression artifacts I'll upload a link to my dropbox with them.
As you can see it still looks fine stretched a bit ! -- If you know the exact dimensions you need I can make further adjustments if you'd like.
Bambam1963:
--- Quote from: kaneda on October 30, 2013, 08:04:35 pm ---About to finalize my custom SF II Mame Pedestal...it's going to be Red...wanted to put SF II CE logos on the side...which location looks best?  Sorry for the ---smurfy--- images, did this in powerpoint quickly...
Far left is my favourite
LeedsFan:
Far left is the best by far. If you decided to adjust the size of the decal then make sure you keep the aspect ratio or it will slightly stretch and look a bit odd. If you go 15% extra width ensure you go 15% extra height as well. Might seem obvious but I've seen that mistake a few times.
JDFan above has toyed with the image for you. The first looks great (is that original dims?) but the second looks odd to me. If it won't fit any bigger then leave it as original.
Pages: << < (3/3)
Go to full version
