| Main > Project Announcements |
| FLYNN'S ARCADE (Project Code Name: Overambitious) - FINISHED |
| << < (3/222) > >> |
| yotsuya:
That CP shape is known affectionately in some circles as 'The Aircraft Carrier'. |
| mcseforsale:
--- Quote from: yotsuya on October 15, 2013, 01:42:20 pm ---That CP shape is known affectionately in some circles as 'The Aircraft Carrier'. --- End quote --- LOL, yeah, but when you have a 32" LCD, there's a lot of real-estate to cover. :bump AJ |
| Nephasth:
--- Quote from: ChanceKJ on October 14, 2013, 11:57:18 pm ----IL Concave RGB/LED buttons (black tops, lit rings) (As seen on the Two-Headed Beast) -Molex QD on all LED harnesses (Also thanks to Nephasth (you bastard, thanks for the expensive ideas... ;) ) --- End quote --- Glad the Beast can still be a source of inspiration! I can help you out with lowering the cost on the Molex parts. PM coming your way. :cheers: |
| ChanceKJ:
| Nephasth:
--- Quote from: ChanceKJ on October 15, 2013, 03:04:38 pm ---Now, ethical question: Looking at all these nice bartops that are being CnC'd is it a sin if i forgo most of the standard fabrication of the cab and have the technical bits plotted out on a local woodworkers CnC? --- End quote --- If you have the resources... Use them! |
| Navigation |
| Message Index |
| Next page |
| Previous page |
