Author Topic: An Original Fix It Felix Build --- 100% Complete!  (Read 119125 times)
Sjaak
Re: An Original Fix It Felix Build
« Reply #160 on: September 29, 2014, 08:26:35 am »
Foil at https://www.onlineprinters.com/
Plexi at http://www.pixartprinting.com/wide-format/printing-flat-bed-rigid-materials/perspex/
Not sure if they ship to the US
Hmm. Is it the "Adhesive film" option? I noticed they have DIN-A1 at €18 including shipping! Perfect for control panels.
Is it sticky on the back or front? I just didn't understand how you mounted it to the plexi. The result is amazing!
Also, I noticed that they don't print white. IMO that's great for bezels, as you don't have to cut out the details, but what if you need white details? White vinyl sticker first, then bezel?
If you want your marquee printed on the back of plexi (like we did), use pixartprinting -> Rigid Media -> Plexi Glass, then choose size and the following material: Clear Polycarbonate (Perspex) 3 mm and make sure you enable "Printing white"
If you want a marquee on thin backlit foil, use onlineprinters.com -> Digital Print -> Posters/Plots, then choose size and the following material: 210 µm backlit film (light box film) for outdoor usage - front side matt
Neither method can be used for bezels!
nordemoniac
  • Weee! Hahaha...
« Reply #161 on: September 29, 2014, 10:02:49 am »
So can the "backlit foil" be the film applied on thin plexiglass, and then plexiglass in front of that?
How about bezel, you'll need something with glue on the front right? A sandwiched bezel would be a bit overkill :P
Sjaak
« Reply #162 on: September 29, 2014, 10:21:22 am »
No, the backlit foil has no "sticky" side, just put it between two pieces of plexi. But the printed plexi is much nicer.
I haven't found a solution for the bezel, these two options will not work for sure. It's difficult to find a printer that can print white and can "print" transparant.
jdbailey1206
« Reply #163 on: September 29, 2014, 10:57:49 am »
Nord - our option here in the states is to go to a printer like Gameongrafix where they can print the monitor bezel and cp artwork and we can apply them to them respectivley.  I am not going to sandwich my monitor bezel but I am going to sandwich my cp artwork between the panel itself and some thin plexi.
jdbailey1206
« Reply #164 on: November 22, 2014, 10:07:44 pm »
Well it has been over a year for this build and I am getting towards the end.  I spent the past two days getting little nuances taken care of.  I spent Friday night finishing up the small things in Windows.  I removed the password protection, changed my wallpaper to the classic 'Winners Dont use drugs', and finally figured out how to make my keyboard shutdown shortcut work properly.  I was getting to the point where a lot of combos didnt work and kept rotating the screen rotation software I had installed.  I finally realized that keyboard shortcuts were enabled on the software and once they were disabled I used Crtl+Alt+6 and it can now be shutdown without use of the keyboard.
Today I cut my marquee and my monitor bezel to size.  I was really reluctant to do so because I had the marquee printed on plexi and it cost me close to $70.  It had to be done though so I bit the bullet. And of course I messed it up slightly.  The flush bit I used did not have the guide tightned down so the first couple inches of my cut was wobbley.  It doesnt really matter though.  The cut is hidden and I cant even tell.
My monitor bezel didnt fair much better.  The first one I cut was accidently dropped when I was peeling the plastic from the acrylic and I created a big scratch when I tried to catch it between my knee and the wood stool I had placed the plastic on.  Needless to say it left a big goige right down the center.   :banghead:  This piece fit perfectly.  The next piece I cut was less then perfect and the cuts were jagged leaving small spaces in between the bezel and the sides of the cab.  Ill head back to one of the big box stores tomorrow and get another piece to cut.  Third times a charm, right?   :lol
The last thing I have to finish is artwork.  All I have to do is find the best printer at the right price and Ill be golden.
ChanceKJ
« Reply #165 on: November 22, 2014, 10:13:28 pm »
http://forum.arcadecontrols.com/index.php/topic,134866.0.html
Wouldn't use anyone else myself.
jdbailey1206
« Reply #166 on: November 23, 2014, 09:27:41 am »
I was thinking of using Brad.  Im working 13 hour days and have a 3 month old so having time to get to a local printer is scarce.  He is in my top 3 printers I am looking at right now.  I havent emailed him for a quote but I did some math based on his topic here and he seems to be the most reasonable.  We'll see what happens.
ChanceKJ
« Reply #167 on: November 23, 2014, 01:42:14 pm »
Even if he was a bit more. Personally I'd  always pay a little more when quality of products and service is that good.
  • Last login:Yesterday at 01:01:52 am
« Reply #168 on: November 23, 2014, 02:01:48 pm »
Agreed. The quality and service is outstanding.
jdbailey1206
« Reply #169 on: November 23, 2014, 04:53:21 pm »
Tru dat.
anx10us
  • Last login:May 29, 2019, 04:36:34 pm
« Reply #170 on: November 24, 2014, 09:59:12 am »
It has been awhile since my last update.  A lot has happened in my personal life and with that I have not had much time to work on my FFJR cab.  No major work has to be done and I am just slowly accumulating all of the artwork.  That being said I purchased the marquee.  I went with Sjaak's advice and went with pixart printing.  Needless to say I was  completely impressed.  I would highly recommend pixart printing if you are looking for a marquee that pops.  Anyway...Enough of me plugging pixart printing.  On to the showcase.   ;D
When I opened the package I was taken aback on how well this resembled a true arcade marquee.  I believe this is how I am going to do marquees from now on.
Hi
I've been lurking your thread for some time and you have inspired me to build my own cabinet, I have been looking at various options for bezel, cpo and marquee. As I am UK based then pixart seems like a god place to get a marquee printed up. I have followed the instructions on which options to choose, however the only art I have is 540x135, I am in effect missing the black borders to take the marquee up to the minimum height on 200mm.  By the looks of it you added a black border top and bottom ? The crucial piece of information I am missing is what size these borders are top and bottom ? Do you have the artwork you used in pdf or jpg ?
Many Thanks
Simon
Sjaak
« Reply #171 on: November 24, 2014, 11:24:55 am »
Hi
The minimum print height is 200mm, so you can just add a 1cm border to the top and 5.5cm to the bottom, or 2cm at the top and 4.5cm at the bottom, or 3cm top and 3.5 bottom, etc. As long as the height is 20cm, it doesn't matter how big the borders are.
anx10us
« Reply #172 on: November 24, 2014, 12:08:05 pm »
Ah ok, I did wonder if there was some specific size for top and bottom due to the size of the marquee retainers ? I shall get one ordered today, one final question (probably) did you get the CPO made in the same way ?
Simon
Sjaak
« Reply #173 on: November 24, 2014, 02:58:15 pm »
Simon
Just remember that you have to cut off most of the black to fit the marquee.
And, no, I just used a sticker for the cpo
anx10us
« Reply #174 on: November 24, 2014, 04:31:29 pm »
Thanks for the information, I don't suppose you still have the original pdf or jpg you used with pixart ? No worries if you haven't, I will fire up gimp and try and figure it out :-)
jdbailey1206
« Reply #175 on: November 26, 2014, 09:04:04 am »
Sorry anx.  I nuked the file after I sent it off to be printed back in September.  And the guy I got it from hasn't been active since March.  Gimp is a good way to go.  I have been in your shoes and needed artwork for a cab.  I'm more partial to Inkscape and I have found that if you have a jpeg of the artwork you need you can just import it and make a vectorized copy.  The funny thing is you can make a better copy than what is actually available.
So heeding everyone's advice I talked to Brad yesterday and I am sending him my artwork later today.  As everyone has said he is very laid back and the beginning of our transaction has been effortless.  Can't wait to get the artwork on the machine so she can go to her forever home.
I had a little hiccup while measuring the CP for the artwork.  Just like last time I almost bent the head off of the KADE controller.   :banghead:  *in my best Norm Macdonald impression*  Note to self:  Put the KADE controller in cab and not on CP for next build.
« Last Edit: November 26, 2014, 09:10:32 am by jdbailey1206 »
JDFan
« Reply #176 on: November 26, 2014, 09:58:20 am »
I downloaded a copy of the FIFjr artwork that was posted and still have it if you want I can upload it to my dropbox and send you a link. It has .eps,.psd and .jpg versions of most of the art (sideart,Bezel,Bezel instruction card, CPO in various layouts, CPO instruction card, Marquee) and is 173MB +\-.
EDIT : I went ahead and uploaded it while typing this so here is the link if you want it ( https://www.dropbox.com/s/ms276eju43l4g8q/Fix%20it%20Felix%20cabinet%20artwork.rar?dl=0 ) -- not sure exactly where I got it from but I believe it was earlier in this thread or another FIFJr thread on this forum but could not find the original link so uploaded my copy instead of linking to it !
anx10us
« Reply #177 on: November 29, 2014, 05:53:06 am »
Thank you for the files, I have everything I need (almost), I have just printed out the plans at 1:1 for the side and off to get some MDF this afternoon, one tiny piece of information that I see different answers for is the inside dimensions of the front of the cabinet ? basically what size should the marquee and bezel be (and hence the front pieces of wood) ?
Simon
jdbailey1206
« Reply #178 on: December 01, 2014, 10:29:47 am »
Simon
Both the Jakobud plans and Buick455 (his measurements are from an actual DK cab that can be found here ) have the inner width of the cab as 22 1/2 inches.  I built mine and just realized it is 22.375 or 22 3/8 inches.  Everything came together on mine oddly enough.
« Last Edit: December 01, 2014, 11:05:37 am by jdbailey1206 »
« Reply #179 on: December 01, 2014, 04:08:42 pm »
Not to nitpick, but are there two spaces after the "of" in "Tobikomi of America" on the marquee? From the angle in the pictures, it kind of looks like it to me.
(Although, it may just be the way the pic appears, or else, the top of the capital "A" which is tricking my eyes.)
jdbailey1206
« Reply #180 on: December 01, 2014, 04:17:28 pm »
HA!  Never noticed that before.  It may very well be.  I didn't create the marquee so I don't know.  The artwork came from Ridicrick.  Too late now.  I already had the marquee printed and installed.
« Reply #181 on: December 01, 2014, 04:28:01 pm »
I wouldn't worry about it. There was all sorts of glitchy stuff on NOS items from arcade manufacturers.
« Reply #182 on: December 01, 2014, 04:34:04 pm »
Exactly this. If anything, I find it more endearing when these little tidbits are found. Nothing is perfect, and even repros can look 'too perfect' if they're dead-on.
Personally, I'm envious of the cab. It looks pretty great.
jdbailey1206
« Reply #183 on: December 02, 2014, 10:42:53 am »
Thanks fellas.  I'm really surprised my OCD isn't flipping out about it.  I worked hard on this cab and I hate to see her go.  But its only going 10 miles up the road to my parents house where it will fit in better.  My old man has a 'gaming room/bar' where it will get more use than if it was at my house.
« Last Edit: December 03, 2014, 10:52:33 am by jdbailey1206 »
jdbailey1206
« Reply #184 on: December 10, 2014, 12:01:22 pm »
Well I thought I was done with this project on Monday but I had a little hiccup.  I received my artwork from Lucian045 (Brad) on Monday.  Except when I opened the package the yellow on the CP and Bezel were more green than yellow.  I looked back at my mock ups I printed last year on another printer and noticed that they were indeed more green than yellow.  Just not as noticable.  I contacted Brad and he is sending me a mock up so we can print the correct yellow.  I want to thank Brad for how helpful he has been working with me.  I also want to thank my monitor for being a dick and showing me the wrong color.  I guess its my own fault for not remembering that when you print it can be physically different than what is one the screen.  I used to hate doing print work in college.   :banghead:
Enough crying out of me.  Below I posted pictures of how well the artwork came out.  Besides the yellow of course.  Now on my monitor the pictures are showing up in yellow but IRL they are a yellowish puke green.  If anyone else sees a off yellow or a greenish color on any of the yellow please let me know.  IRL it is considerably noticeable and I wasn't going to have it on the cab after working so hard on the rest of the cab.
« Last Edit: December 10, 2014, 12:04:02 pm by jdbailey1206 »
pinballsmith
  • Last login:May 13, 2024, 06:34:56 pm
« Reply #185 on: January 31, 2015, 07:04:31 pm »
Sorry for bringing this topic back up, but I did find a picture of the paint brand that was used. I also have the color code thanks to someone on the inside. I'm trying to fix some damage on my latest Felix machine and would love to use the exact same paint if anyone knows what this brand is.
jdbailey1206
Re: An Original Fix It Felix Build --- 99% FINISHED!
« Reply #186 on: February 17, 2015, 03:12:45 pm »
I finally got all my artwork issues resolved.  Unfortunately I did not get the finished product through Brad.  He could not fix the yellow on the files I had sent him so he was awesome enough to refund me half my money (shipping and cost of materials).  I finally realized that the files I kept sending him were not completely vector.  They were saved as .eps but being a dummy I did not realize that the images that were contained in the file were raster.  Brad explained this to me and I hung up the phone.  Later that day I realized what I had done and instead of wasting anymore of Brads time I reworked the files over the weekend (into actual .ai vector files) and took them to a local printer where I could more of a hands on experience.
My local printer printed me off a quick mock up of the files (so I could check the yellow this time  :laugh:) and I accepted them and had the artwork by Tuesday of the following week.
In the meantime I took the time to sand down and throw a couple of layers of Kilz on my control panel at the behest of those on the forum.  I'm glad I did because I would have wasted my CP artwork.  The paint doesn't give too much of a texture but enough to give something for the artwork to grab onto.
Over the following weekend I was ready for my artwork.  The side art, which I thought would be the toughest, went on the easiest.
The first thing I did was measure each side to see where exactly I wanted the artwork.  Now from what I have read on the internet there is only a 2 3/4" space between the top of the DK side art and the top of the cab.  That to me seemed a little high even for DK so I just looked online for the side of a FFJR cab and placed my artwork accordingly.  Most of the pictures I saw placed the bottom of the artwork even with the bottom of the speaker grill panel so I went with that.
To make sure my side art stayed in place I placed some tape to keep it from moving.  The larger piece of tape was to keep the artwork down when I removed the upper part of the backing to finally squeegee it in place.
After I got the side art like the picture above I cut off the small part of backing and squeegeed the top part to the cab then began peeling and applying pressure to the rest of the artwork which went on wonderfully.
Final application goodness.
After the side art was applied I turned to the control panel.  In my haste of reordering the new artwork I forgot to tell my new printer that I needed a matte finish on my control panel.  After I got it applied with no problems I put the plexiglass on top and began to tighten down my bolts to keep the plexi in place.  As I did I realized that I was getting odd smudges all around where the bolts were putting pressure on the plexi.  I was also experiencing this problem even worse near where the push buttons were at.  Half way through I realized my artwork was gloss so when the plexi glass met the gloss of the CP it left smudges.  I already had my artwork applied and I was not going to rip it off and spend another $40.00 getting new artwork.  It was fixed easily enough by putting small, thin washers between the CP and the plexi.  You can see how poor it looked in the picture below before I put the washers in.  Note the lower corners and around the push buttons.
I also applied my coin door decal set from thisoldgame.com  I'll post a better picture when I take it.  The one I took is a little tilted.  I think I was high on paint fumes when I took it.   ;D
I saved what I thought would be the easiest art to install for last.  This being the monitor bezel artwork.  I.  Was.  Wrong.   :banghead:  I should have known when you cut the middle out of something it would make the structural integrity weaken.  It took me two times to get it right.  The first one I tried, I ripped in half when I tried to apply it.  The second one was a little better.  I also used the wet method this time and it was easier to re-position.   I still had a tiny rip in the bottom left hand corner about 1/4" long but its hardly noticeable and I think it gives the bezel a NOS look.  Like it has been sitting in a warehouse for about thirty years until I dusted it off and placed it in my cab.   :laugh:
Here is the machine sans bezel art:
And the bezel artwork applied:
Don't mind the black dots on some of the pictures.  They were taken with my phone and I forgot to clean my lens before I took the pics.
Well that is it for now.  The only thing I have to do is remap a credit button and I should be good.  I'll try to get some better pictures up when she heads to her forever home.  I also want to get a quick video shot of it being played.  We'll see how it goes.
I learned a lot on this cab.  Some things were new others were things I should have remembered from my weecade.  (Like how plexi and gloss artwork don't mix.)
This is should be it on major updates.  The next one probably wont happen until its moved in the spring.  As much as I want it traveling in the open bed of my truck in this wonderful Michigan weather.   ;D  I also wanted this cab done by the end of last year to hopefully get nominated for the UCA but, Hell, how many times can a FFJR be nominated for a dedicated fullsize.  Props to Sjaak for winning last year.  He was a major influence on me building this cab.
« Last Edit: February 17, 2015, 03:22:54 pm by jdbailey1206 »
ChanceKJ
« Reply #187 on: February 17, 2015, 03:49:22 pm »
 :applaud: lovely. Great job on this.
I'm interested to see the work you did on vectoring the art. I know just looking at the standard art package floating around that a good fully vectored version is a long overdue replacement. If you'll share that is ;) seriously no pressure.
« Reply #188 on: February 17, 2015, 03:59:35 pm »
Another vote for this, if you'll share. I'm also interested in seeing the missing art from the movie incorporated into these builds - like the missing bezel instructions. I haven't seen anyone put these on a cabinet yet.
jdbailey1206
« Reply #189 on: February 17, 2015, 05:12:10 pm »
Chance - Just send a self addressed envelope along with your PlayChoice in a box and I'll see what I can do about sending you a copy on a flash drive.   ;D
Rick - I do have a copy of the bezel instructions.  I was on the fence about putting it on there but I have a feeling it will end up being placed on.
ChanceKJ
« Reply #190 on: February 17, 2015, 06:58:46 pm »
Hmmm.... Sounds legit.
 :lol
ChanceKJ
« Reply #191 on: February 17, 2015, 07:00:29 pm »
On second thought, you probably won't want it. I'm ripping it out of that SNES controller one day and repurposing it for a future Nintendo theme'd project. Then keeping the controller as a USB Device.
jdbailey1206
« Reply #192 on: February 18, 2015, 09:15:11 am »
I forgot in my last post but I wanted to thank the following people for helping me in this endeavor:
Automark, meyer980, wp34, Generic Eric, Pixel Paul, Louis Tully, pinballsmith, jmike, YOTSUYA, Malenko, SORHP, talkgeek, 404, PL1, Santoro, koolmoecraig, Sjaak, ridicrick, ChanceKJ, JDFan, Rick.  (And anybody I forgot...)
If you were listed but didn't feel like you helped in any way your words of encouragement motivated me immensely.  I tend to get bored with things and your words helped me reach the finish.  Thanks again guys.   :cheers:
« Last Edit: February 18, 2015, 09:21:17 am by jdbailey1206 »
« Reply #193 on: February 18, 2015, 09:41:36 am »
WTF? Why is my name so big?
« Reply #194 on: February 18, 2015, 09:43:05 am »
He's seen you in the showers?
« Reply #195 on: February 18, 2015, 09:48:38 am »
jdbailey1206
« Reply #196 on: February 18, 2015, 10:14:40 am »
As much as I wamt to make fun of Yots for having a small penis (ALLEDGELLY) I enlarged your name for shits and giggles.  You thanked me when you didnt have to and I returned the favor.
« Last Edit: February 18, 2015, 10:22:49 am by jdbailey1206 »
« Reply #197 on: February 18, 2015, 10:28:10 am »
Man, my BYOACation can't come soon enough.
ChanceKJ
« Reply #198 on: February 18, 2015, 11:38:12 am »
Wait, I was helpful??   ???
« Reply #199 on: February 18, 2015, 11:45:14 am »
Of course you helped. I wasn't going to do any bezel art, save for the instruction cards, and you gently nudged me in that direction (with YOUR small penis, btw). For that, I was grateful.
