Author Topic: Monitor without VESA mount and cable jacks in stand base  (Read 1410 times)
VoltaTom
  • Last login:November 11, 2018, 09:42:10 pm
« on: October 11, 2013, 10:28:13 pm »
[EDIT]: I didn't get the monitor, but am still curious if someone has used a monitor with those type of connections in a cabinet?
Hello everyone,
I found a used 19" LCD monitor - NEC MultiSync LCD1935NXM - for a good price. It looks like it would be tough to mount for a cabinet - but am not certain. Is it really that bad? Is it worth the trouble when the inputs are in the base? Has anyone done this before?
« Last Edit: October 12, 2013, 03:44:46 am by VoltaTom »
CoryBee
  • Last login:October 21, 2023, 07:12:25 pm
  • Bopity Boopy
Re: Monitor without VESA mount and cable jacks in stand base
« Reply #1 on: October 12, 2013, 05:56:16 am »
Unless it is like $5 - $10 I would stay away. Too much hassle. Where are you located?
Louis Tully
« Reply #2 on: October 12, 2013, 06:53:21 am »
« Last Edit: February 12, 2015, 03:55:46 pm by Louis Tully »
VoltaTom
« Reply #3 on: October 12, 2013, 10:16:51 am »
It was more than that. I'm glad I didn't get it.
I'm in the GTA in southern Ontario.
Sent from my iPhone
VoltaTom
« Reply #4 on: October 12, 2013, 10:32:51 am »
Hello everyone,
As long as the base didn't get in the way of mounting - tilts back far enough to allow the monitor to be flush against a flat surface - you could use L-brackets. Bend the brackets to a custom fit and you don't have to attach anything to the actual monitor. It just sits in its new 'slot' and gravity does the work. This is how I set stuff up. Not saying it's the best or anything, it's just how I do it. I've never used the vesa mounts for arcade stuffs. YMMV.
A good idea! Might do that if I get one without the VESA mount holes. That monitor has the connections in the screen still. I feel like that may be more of a challenge?
Sent from my iPhone
CoryBee
  • Bopity Boopy
« Reply #5 on: October 12, 2013, 10:51:11 am »
Save yourself some hassle if you just get one with VESA mounts and a slab of wood to drill the 4 matching holes in.
Measure to half the width of the tv support piece. Then measure 2 inches out either side of the middle mark. Then measure 4 inches down from those marks.
Basically, the VESA mounts for those size screens *almost* always have the holes 4 inches apart from each other. Measure on your LCD before hand obviously to make sure.
Hope that made sense, tis morning and didn't sleep much......
VoltaTom
« Reply #6 on: October 15, 2013, 08:51:04 pm »
Yeah I definitely don't think it would be worth it without the VESA. Ended up with a used HP LP1965. Good price, hard to turn down.
