Author Topic: Turning on PC - button extension?  (Read 896 times)
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
« on: October 08, 2013, 03:33:32 pm »
How do you all turn on your MAME PC, which is insided your cabinet??
Perhaps a rewiring to a button somewhere along to cabinet?
brad808
  • Last login:May 22, 2023, 08:18:15 pm
Re: Turning on PC - button extension?
« Reply #1 on: October 08, 2013, 03:48:54 pm »
That's what I did. Stuck a spare arcade button up top at the back and wired it to the power on the mother board
Sent from my Nexus 4
kiwasabi
  • Last login:September 28, 2014, 12:14:51 pm
« Reply #2 on: October 08, 2013, 03:53:27 pm »
Then you can also get a smart strip and set your PC as the master port, with your speakers, lights, monitor, etc being set as slave ports. So when you use that external PC power button it actually turns everything on and off. This is the one I used:
http://www.amazon.com/gp/product/B004H1PV4S/ref=oh_details_o04_s00_i00?ie=UTF8&psc=1
matt4949
« Reply #3 on: October 08, 2013, 05:23:57 pm »
I have this Dell in my cab and followed this video to the letter. Worked great.
EMDB
  • Project RetroCade
« Reply #4 on: October 08, 2013, 05:30:55 pm »
Or set the PC to boot at power on in the BIOS and simply connect everything (PC, monitor, power adapters, ...) to a single mains power switch.
Thats what I did. I use a DELL Optiplex PC 745...
DHTech
  • Last login:November 29, 2014, 03:48:36 pm
  • Arcade Flashback
    • Arcade Flashback - Hand Made Custom Arcade Machines UK
« Reply #5 on: October 09, 2013, 03:48:39 am »
Most PC don't have power on in the bios settings, only power on in the event of power failure, so this wouldn't work, also wouldn't use that type of switch to turn on your PC, you need a momentary switch (non-latching).
EMDB
  • Project RetroCade
« Reply #6 on: October 09, 2013, 03:58:02 am »
You don't quite get it: The switch is used to switch the power of the PC not to trigger the PC's power switch. TS mentioned a DELL PC and at least they have the power failure setting as that is the trick: you simply put power on the mains supply of the PC which triggers booting the PC due to the power failure setting. You never use the PC's power switch this way.
« Last Edit: October 09, 2013, 04:02:52 am by EMDB »
DHTech
  • Arcade Flashback
« Reply #7 on: October 09, 2013, 04:06:44 am »
Correct me if I'm wrong, but what you are suggesting is to power on the PC using the BIOS power failure settings! this is a terrible idea, you asking for trouble as you could easily corrupt the OS by not shutting down the PC properly.
jimmer
  • Last login:March 17, 2024, 06:03:11 pm
  • I want to play Defender like at the arcade.
« Reply #8 on: October 09, 2013, 05:34:00 am »
I was gonna ask EMDB about power down. But as he doesn't seem to have a cab that won't have been a problem for him yet.
Do all PCs (windows operating systems) have a nice clean shutdown by physical button?
On forums jimmer speaks for himself as a Defender fan, not as proprietor of www.jbgaming.co.uk  << Is that advertising or disclosure ? or both ?
EMDB
  • Project RetroCade
« Reply #9 on: October 09, 2013, 05:51:25 am »
I never said I shut down the PC using the power switch.
I DO have a cab (see my signature). I turn it on using the power switch (which boots the PC directly into Hyperspin). I let Hyperspin shut down Windows on exit. Afterwards I turn the whole cab off with the power switch.
« Last Edit: October 09, 2013, 05:54:27 am by EMDB »
CoryBee
  • Last login:October 21, 2023, 07:12:25 pm
  • Bopity Boopy
« Reply #10 on: October 09, 2013, 06:45:28 am »
This has came up plenty of times. Mention this in the first post next time. People don't seem to get you can shut down through your fron-end on exit.
welshjpc
  • Last login:March 12, 2020, 04:11:52 pm
  • Golden Tee cab project COMPLETE! :-D
« Reply #11 on: October 10, 2013, 02:07:11 pm »
Yip I've just used one of the operator buttons behind the coin mech door, wired that to the connector on the motherboard. One advantage of that is my 4 year old can't just switch the cab on whenever he wants to as the door is locked when I'm not about. You can set windows to power off the PC with the power button as well so once the cab is finished with its just one button press, then Maximus & windows shut down and then the PC powers off. And as a matter of habit I always then switch it off at the wall when I'm done so the monitor doesn't stay on standby for hours.
