Main > Main Forum
Wire colors
jdbailey1206:
--- Quote from: TopJimmyCooks on October 08, 2013, 01:11:19 pm ---Black with black labels with black letters on the labels. You know, so you can tell what's what.
:lol
RandyT:
As a side note, we've started shipping 10 color wire kits as options for our interfaces as well. They used to be all black, but the cost was no different, so we decided to go that route. It doesn't make much difference in the long run, with even CAT5 being a decent option. Where low-voltage/current wiring is concerned for your own projects, if it holds reliably in the connectors, can be handled easily, and it gets the signal from A to B, you are golden.
Locke141:
I am now doing the wiring for my first CP. I like my idea so I am going to share and hope it works out well.
I'm using colorer coded cat-5, the out side of the cable will match the player buttons. The wiring in side the cat 5 will correspond to the same buttons for each player. All the solid colors will be in the same order yellow, blue, green in the top row and all the striped colors will be on the bottom row in the order stripe, yellow stripe, blue stripe, green stripe. I will do the same for the joys stick but with a black strip made with a marker on the cat 5.
Nephasth:
Pfft. Labels are for ---Bad words, bad words, whatcha gonna do? Whatcha gonna do when saint censors you?---. :P
:lol
matt4949:
--- Quote from: Nephasth on October 08, 2013, 07:55:05 pm ---
:lol
Yeah, ---Bad words, bad words, whatcha gonna do? Whatcha gonna do when saint censors you?--- and guys that know what they're doing. Luckily ain't no one like that around these parts.
