Author Topic: ServoStik Questions  (Read 1518 times)
markronz
  • Game on!
ServoStik Questions
« on: October 06, 2013, 01:59:03 pm »
Just some quick questions about the ServoStik joystick I was hoping someone could help me with...
1.  If I an using a 5/8" thick MDF board for the control panel, could I under mount these joysticks?  Or would I have to mount them on the top and route out the area for the mounting plate to sit on?  I didn't know if there were a longer shaft I would need or something, if that's even available?
2.  Regardless of which method I would have to mount these, are there other balltop options out there that would be compatible?  Ultimarc only seems to have the red balltop and then two oval tops.   Ideally I would like a blue balltop but again, I just don't have a good understanding of which sticks/shafts might be compatible, if any.   I might be interested in an illuminated joystick too, if those are available.  So if anyone could help point me to the different sticks that would work, I would greatly appreciate it.
chopperthedog
  • Last login:Today at 07:19:39 am
Re: ServoStik Questions
« Reply #1 on: October 06, 2013, 02:09:18 pm »
Depends on the over all height that you prefer. On my SI ptII cocktail they are mounted to non routed 1/2" plywood, the plastic control panel cup and the aluminum cpo which totals to about 3/4" and imo they end up at the perfect height for that purpose. You'll just have to make that call when you have one in hand.
For the custom balltop route I think you only have 1 option.  http://www.paradisearcadeshop.com/hollow-shafts/733-magstik-10mm-stainless-steel-hollow-joystick-shaft.html
good day.
markronz
  • Game on!
« Reply #2 on: October 06, 2013, 02:43:48 pm »
Thanks for the info.  So a servostik uses the same shaft as a magstik plus?
chopperthedog
« Reply #3 on: October 06, 2013, 02:50:52 pm »
Derp!!! Got my ultimarc sticks mixed up :P. The balltop on the servostik unscrews and has an M6 thread (The balltop on the magstik does not unscrew) and that's where I confused myself.
good day.
markronz
  • Game on!
« Reply #4 on: October 06, 2013, 03:20:21 pm »
Sorry I don't know these details yet.  Is M6 a common thread or something?  I thought I read the servostiks are like JLWs, so does that mean I could use something like this?
http://www.paradisearcadeshop.com/hollow-shafts/728-jlw-10mm-stainless-steel-hollow-joystick-shaft.html
severdhed
  • RIP Dinosaur Hippo
« Reply #5 on: October 07, 2013, 12:30:16 pm »
The servo stick is a modified jlw, there are lots of ball top options...I used the handcandy ball tops from groovygamegear on my JLW sticks and they are really nice. I under mounted mine in 3/4" mdf with 1/8" plexi on top. I used a router to recess then about half the thickness of the mdf, I think the height of them is perfect this way.
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=70&products_id=368
Sent from my Galaxy SIII using Tapatalk.
« Last Edit: October 07, 2013, 12:32:40 pm by severdhed »
markronz
  • Game on!
« Reply #6 on: October 07, 2013, 12:40:09 pm »
Thanks for the info!   I did actually hear back from Andy today at Ultimarc as well.  He said this:
"The shaft is standard Sanwa JLW which has a 6mm thread. So standard ball tops from other suppliers can be used"
So it sounds like I should be able to find a hollow stick from Paradise Arcade if I decide to go with a LED joystick.  Otherwise, I could just seemingly find a balltop from Paradise or GGG (and I'm sure other sites) as well!   So I think I'm all set on this topic.  Thanks for the help everyone!
