Author Topic: Galaga 3 Cocktail Conversion  (Read 2472 times)
rosemountain
  • Last login:October 08, 2013, 04:18:04 pm
« on: October 06, 2013, 07:54:09 am »
I am  converting my original Galaga 3 non Jamma wired cab to a Jamma 60-in-1. I purchased the pcb and harness. I verified that there is a 5v and 12v power supply. My question is, does anyone know of an adapter that I could plug in the existing Galaga 3 harness to convert to Jamma ?
Or do I have to re-wire the cab completely to plug into the new Jamma harness?
JDFan
  • Last login:May 21, 2023, 04:07:42 pm
Re: Galaga 3 Cocktail Conversion
« Reply #1 on: October 06, 2013, 10:17:02 am »
This machine made JAMMA Adapter is designed to convert Galaga / Bosconian PCB signals to work correctly in a standard JAMMA arcade cabinet.
This Adapter will work with the following non-JAMMA PCB's:
* Galaga
* Galplus
* Galaga 3
* Bosconian
http://www.jammaboards.com/store/galaga-bosconian-to-jamma-cabinet-adapter-galaga2jamma.html
  • Last login:April 28, 2024, 12:59:28 pm
« Reply #2 on: October 06, 2013, 12:35:31 pm »
That's not what he's looking for.
JDFan
« Reply #3 on: October 06, 2013, 05:37:26 pm »
Ahh - read it wrong - was this the one then ? (though it shows out of stock) -- http://www.jammaboards.com/store/jamma-to-galaga-bosconian-cabinet-adapter-jamma-2-galaga.html
rosemountain
« Reply #4 on: October 06, 2013, 07:41:06 pm »
Thanks ! So the Jamma-to-Galaga cabinet adapter is the one ? The connector looks right.
I appreciate the help!
JDFan
« Reply #5 on: October 06, 2013, 09:51:20 pm »
I believe so -- since you are wanting to go from a Jamma PCB (60 in  1) to the Galaga 3 cabinet -- The first one I linked is the opposite going from a galaga 3 PCB to a jamma cabinet so would be the wrong one as Yotsuya mentioned - but you may want to wait for verification !
Found a link that shows them available for $40 ( http://cambridgearcade.dyndns.org/?q=node/8 ) but not sure how old the post is but worth checking.
« Last Edit: October 06, 2013, 10:16:54 pm by JDFan »
rosemountain
« Reply #6 on: October 07, 2013, 04:05:50 pm »
Thanks, I think the board from Jammaboard.com matches the harness from my Cab as it has the 2 cut outs on the male side that are needed. The one from cambridge does not appear to have it unless I am missing it.
