Main > Main Forum
Made my own williams multigame CP (with a little customisation)
Pages: << < (2/2)
paigeoliver:
Looking at the underside of your panel your restriction plate doesn't have a circular movement pattern. If you aren't a Robotron pro then it really won't matter. If you are then anything other than a circular movement pattern on the stick will make the game quite unenjoyable.
What game is run, jump and run for? Track and Field?
--- Quote from: subzero1970 on September 30, 2013, 03:17:35 pm ---
--- Quote from: paigeoliver on September 30, 2013, 02:27:27 pm ---Robotron NEEDS a round joystick movement pattern if you want any hope of being good at it. Looks like those are square or octagonal. I thought I could get away with a square pattern on my multiwilliams and I replaced them within 2 days.
seems to work fine for robotron, and besides im not sure what you mean...
UFO:
I like it, and the idea.  :applaud:
Not sure if 'Reverse' is a little too far away to be flicked by the thumb though....
subzero1970:
--- Quote from: UFO on September 30, 2013, 03:34:10 pm ---I like it, and the idea.  :applaud:
reverse fits my thumb just fine :)  on my V1 it was further away and lower down too!!!
yeh the 3 lower buttons are for TnF and HS (and other regular 3 button games)
if you look at the attached file, that was my V1 CP - oh my god!! it was all guess work with a horrible white marble finish!
Sz
UFO:
--- Quote from: subzero1970 on September 30, 2013, 04:05:12 pm ---
Sz
Good stuff.
Its a great concept, and you executed it really well ... :applaud: :applaud: :applaud:
paigeoliver:
I have my reverse in the same place. It works fine as long as you haven't trained yourself with a couple decades of Stargate and Defender on the original panels.
One minor quibble though is the fact that you become worthless on a real Defender layout once you train yourself to use the Multiwilliams one.
Pages: << < (2/2)
Go to full version
