Main > Main Forum
Aim Trak Recoil Kit
Pages: << < (3/3)
TopJimmyCooks:
I think I ended up with an extra 36V power supply - so give a shout if you go recoil - I'll make you a good deal if you want it.
thrasherx:
--- Quote from: TopJimmyCooks on September 17, 2013, 04:20:44 pm ---I think I ended up with an extra 36V power supply - so give a shout if you go recoil - I'll make you a good deal if you want it.
Will do. Thanks, man.
thrasherx:
How should I plan on incorporating my sensor bar into my painted acrylic LCD bezel? Do the UV LEDs always glow?  I'm assuming that tint is ok, but paint blocks them completely.
Drakin:
Yea the UV LED's are lit at all times, I've seen where people have drilled holes in there bezel the size of the led's so they just poke through...Tint is ok...I know in the software that you can adjust the output, As long as the gun can see the led's you should be ok.
thrasherx:
--- Quote from: Drakin on September 25, 2013, 10:06:39 pm ---Yea the UV LED's are lit at all times, I've seen where people have drilled holes in there bezel the size of the led's so they just poke through...Tint is ok...I know in the software that you can adjust the output, As long as the gun can see the led's you should be ok.
Sent from my iPhone using Tapatalk - now Free
Pages: << < (3/3)
Go to full version
