Main > Main Forum
Looking for small 20 wire connector
ed12:
then as TopJimmyCooks
pointed out digikey or mouser
u must pick what u want :panel mount: or :twin in-line: with hood's
just as easy to take 25pin to 25pin male to male
and go to what ever with it..
ed
TopJimmyCooks:
for drop in controllers with a lot of connections look at pogo pins as well from digikey or mouser. They've always been too pricy for me but one day someone will do something sweet with them.
tony.silveira:
man i'm lost on that site. i found a couple that could work but in all honesty, i'll probably go with two vga connectors or one vga and one minidisplayport (might as well and try to salvage what i've bought).
i just can't find that ne connector where i say "THAT'S IT!"
if anyone has any suggestions, here is what i'll be doing and using my current vga connectors as examples:
on my panel, centered top above the trackball, i'll be flush mounting my male vga connector. you'll be able to wipe your hand over and not feel a lip.
then on the bottom of each swappable controller, the female connection will be surfaced mounted so that when lowered into place, it will plug into the panel connector.
some of the stuff i saw on mouser that have the pin count i would need to wire, almost like a molex connector. i can certainly do this but i always found the housing and pins to have a bit to much play in their sockets so hoping someone has the magic pin/plug i'm looking for that they can recommend. hell, i even thought of a cartridge board/socket taken from a gameboy but i think that cartridge board sticking out of the bottom of the add ons could end up breaking.
i appreciate it guys, a lot. thanks
JDFan:
DO you have any old PC MOBOs and PSUs laying around ? -- perhaps use the 20 or 24 pin MOBO power connectors.
PL1:
How about this 26 position high density d-sub? (like a VGA connector, but wider)
Plug
Receptacle
Found on page 227 of the Allied catalog. (upper right corner)
