Main > Driving & Racing Cabinets
Sega Monaco GP 1979/1980 - My Remake
neilsnonsense:
Please paste the entire command line you are using. I just verified that it works on both Windows 10 and Linux.
If you have the correct command line, you should not see the menu or prompt.
hafoudha:
--- Quote from: neilsnonsense on March 18, 2023, 10:28:29 am ---Please paste the entire command line you are using. I just verified that it works on both Windows 10 and Linux.
thank you so much for being patient. here's what I get for now, I hope I'm on the right way.
neilsnonsense:
--- Quote from: hafoudha on March 18, 2023, 02:22:25 pm ---here's what I get for now, I hope I'm on the right way.
I think I see your problem. You are invoking the mgpr.exe executable from your your home directory root by passing an absolute path to it. The game needs your 'current working directory' to be the game directory, i.e. mgpr_v1_4_6
In other words, you need to invoke it like this (assuming your starting point is C:\Users\hefdh):
cd Desktop\mgpr_v1_4_6
mgpr.exe -cfg classic_8bit_1280x1024.cfg
Hope that helps.
hafoudha:
--- Quote from: neilsnonsense on March 20, 2023, 11:04:22 am ---
Thank you so much, my folder is in my Desktop, and when I followed your instructions, I get this screen, and the cfg starts the game by itself, I then play few seconds and exit the game, launch again and the full list of cfg is there to chose from, it's not defaulting yet.
Hope that helps.
neilsnonsense:
--- Quote from: hafoudha on March 20, 2023, 01:30:17 pm ---Thank you so much, my folder is in my Desktop, and when I followed your instructions, I get this screen, and the cfg starts the game by itself, I then play few seconds and exit the game,
That message looks like a problem between the game and your sound card/driver. Unfortunately I can't help with that beyond recommending you try switching the audio output device from Windows' audio settings if you have more than one device available? When you played for a few seconds did you hear any audio output from the game?
--- Quote from: hafoudha on March 20, 2023, 01:30:17 pm ---launch again and the full list of cfg is there to chose from, it's not defaulting yet.
When you say launch again, did you use the exact same command line? Or are you expecting this setting to be 'sticky'? Because it isn't. Just to be clear, every time you launch mgpr.exe without the -cfg option, it will display the menu regardless of how you launched previously.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
