Main > Main Forum
Building a Full-Size machine for $350 or less
Pages: << < (5/5)
Nephasth:
--- Quote from: Connorsdad on September 07, 2013, 01:36:45 am ---If I'd known it was going to cost this much I don't think I would have started lol.
Really? Griff had cost break down in the first post of his thread:
--- Quote from: griffindodd on July 20, 2012, 03:45:59 pm ---Current Cost List:
Raw Materials:
$45 - Framing Wood - Home Depot
$80 - MDF Panels (2x 5/8" 8x4) - Home Depot
$18 - 3 boxes of Kregg pocket screws - Home Depot
$45 - 5x tins of Loctite 300 Heavy duty spray contact Cement - Amazon
$35 - 5x tins of Rustoleum Textured matt black paint - Home Depot
$184 - 5x 8x4 sheets of Wilsonart 1/16th vertical matt black laminate (delivered) - eBay
$20 - Clear Acrylic 24" x 12" 3/8" - Amazon
$15 - Smoked 1/8" 48" x 12" acrylic - Amazon
$?? - Custom cut and fabricated diamond plate - ????
$60 - 250' Red 11/16" T-Molding - Tape Ease
$110 - 3x custom cut 3/16" smoked glass (Delivered) - www.OneDayGlass.com
$612
Controller Hardware
$150 - (Unused/second hand) 15 Ultralux RGB Buttons+harness, 2x Paradise LED top 8-way sticks, 2x Coin Buttons, 2 player buttons, PAC64, iPac V2 - Forum Member.
$15 - True4-way stick - GGG
$150 - Trackball with RGB lighting and controller board - Forum Member Ron310
$75 - Extra RGB buttons for pinball - Ultimarc
$210 - Lilliput 7" Touchscreen - Amazon
$20 - Wire & connector blocks - Home Depot
$60 - Second PAC64 - Ultimarc
$680
Screen Rotation Mechanism
$32 - 1 x Pololu Simple Motor Controller 18v7 - Pololu
$16 - 1 x Amico 12v 10rpm 15kg/cm 130mA motor - Amazon
$7 - 1 x Pololu 37D mm Metal Gearmotor Bracket Pair - Pololu
$7 - 1 x Pololu Universal Aluminum Mounting Hub for 6mm Shaft Pair, 4-40 Holes - Pololu
$13 - 1 x #1700 Premium Jumper Wire 50-Piece Rainbow Assortment F-F 6" - Pololu
$12 - 2x Microswitches for stop limits- Amazon
$87
Sound & Lighting
$100 - Eagle 140W 2.1 Computer Speakers - Frys
$49 - 16ft length of RGB ribbon lighting + Sound sensitive lighting controller - Amazon
$22 - 120w 12v DC power supply - Amazon
$171
CPU & Screens
$49 - ASROCK H61M/U3S3 H61 Motherboard - Newegg
$49 - INTEL CELERON G530 (Sandybridge) 2.4Ghz Dual Core - Newegg
$45 - MEMORY 2x 4GB DDR3 GSKILL F3-8500 - Newegg
$40 - 300w Power Supply - Newegg
$60 - 1TB 7200rpm Hard Drive - Newegg
$140 - LG 23" 16:10 LED IPS Ultra Slim Monitor - Frys
$90 - BenQ 15" 4:3 LCD monitor - Frys
$12 - Blue LED Hard Drive Cooler - Amazon
$35 - Griffin Powermate USB Volume dial - Amazon
$40 - 2x Custom messaging 120mm fans
$558
Artwork & Graphics
$230 - 2x Custom sides, 1 custom marquee - Game On Graphix
$60 - Full color large format bezels and marquee mock art - Staples
$20 - Control panel large format color - Staples
$50 - Template black and white line art - FedEx/Kinkos
$340
Misc
$50 - X-Gaming Coin Door & Mech - XGaming.com
$38 - 10 Outlet Smart Strip - Amazon
$300 - A bazzillion little bits and pieces from 400+ Home Depot trips
$388
Totals up to $2836 :dizzy:
CoryBee:
--- Quote from: ark_ader on September 07, 2013, 10:52:30 am ---
--- Quote from: CoryBee on September 07, 2013, 10:39:19 am ---
--- Quote from: JDFan on September 06, 2013, 12:27:24 pm ---Smart Strip or other power strip.
Wanted to touch on this.
Power Strip -
I usually just buy them in bulk at any local store or if there is a sale or something but here is a pretty cheap one from eBay that would work well if you only need 3 plugs. I haven't used store bought smart strips, I have however built my own per this thread. Lately I have been trying to get TVs that run on DC voltage and wiring them to the PC power supply. As well as wiring up the Marquee light and the PC speakers allow for a no smart strip, smart power on.....
There are a bunch of monitors that use a separate power brick.  Digimate is a brand that is infamous for these bricks with awesome displays.  If you can get your cab to be DC only, it would save a bunch of money.
Yea I thought it was a pretty nifty way of going about a "smart" power system. Can not only bypass the smart strip this way but also bypass a power strip at all.
Fursphere:
--- Quote from: CoryBee on September 07, 2013, 11:04:42 am ---Yea I thought it was a pretty nifty way of going about a "smart" power system. Can not only bypass the smart strip this way but also bypass a power strip at all.
If you could "cleanly" gut a laptop and re-use all the parts, it would be the way to go.  But that's a lot easier said than done.
Maybe we should call Ben Heck?  :)
CoryBee:
--- Quote from: Fursphere on September 07, 2013, 12:07:23 pm ---
What do you mean? Can you elaborate more?
All of my bartops were laptop conversions and everything was ran off of the original power brick.
Connorsdad:
--- Quote from: Nephasth on September 07, 2013, 11:02:28 am ---
Raw Materials:
$612
Controller Hardware
$680
$87
Sound & Lighting
$171
CPU & Screens
$558
Artwork & Graphics
$340
Misc
$388
I had the blinkers on and didn't even see the total cost, I just saw the cab that I wanted and went for it lol.
Sent from Amstrad CPC464
Pages: << < (5/5)
Go to full version
