Author Topic: touchpad to control music  (Read 1233 times)
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
« on: August 27, 2013, 11:45:01 pm »
about to set touchpad to control my music with musicbee on my arcade
« Last Edit: August 27, 2013, 11:48:12 pm by Caparo8bit »
Caparo8bit
  • Hyperspin/Maximus
Re: touchpad to control music
« Reply #1 on: September 04, 2013, 12:38:04 am »
what you guys think about my control panel need opinions for final product will b made of brushed aluminum and has to b 100% good thanks
  • Online Online
  • Last login:Today at 12:28:31 pm
« Reply #2 on: September 04, 2013, 02:03:27 am »
:dizzy:    :dizzy:   Have you made a cardboard test panel in that configuration and tried to press the buttons?   :dizzy:    :dizzy:
Seems like P1 buttons are tilted so far clockwise that it will force P1 to stand further left which can mess up game play big time.
Go to Slagcoin, find a layout you like, print it twice, tape it to the cardboard, cut out the holes, install the buttons/joystick and see how it feels.
Also with that much real estate, why are the admin buttons so darn close and in the wierd "W" pattern?
« Last Edit: September 04, 2013, 02:07:53 am by PL1 »
  • Last login:April 28, 2024, 12:59:28 pm
« Reply #3 on: September 04, 2013, 02:47:57 am »
What's the difference between Home and Esc?
And I'd put P1 and P2 lower, in place of Home and Escape. You don't want anyone reaching OVER Esc to press anything and accidentally exit you out.
severdhed
  • RIP Dinosaur Hippo
« Reply #4 on: September 04, 2013, 11:20:18 am »
I agree... make a cardboard mockup of your panel and see how it feels.
Here are some thoughts on admin buttons..
I highly advise against a power button on your control panel, it will get pressed accidentally and it will piss you off when it happens.
What is the home button for?
Do you plan on having a pause button?
I'd keep the start buttons away from any admin buttons to avoid confusion. You know what the buttons do, but other people will not.
« Last Edit: September 04, 2013, 11:21:54 am by severdhed »
severdhed
Re: Re: touchpad to control music
« Reply #5 on: September 04, 2013, 11:21:24 am »
accidentally double posted and don't know how to delete it...please ignore
« Last Edit: September 04, 2013, 11:34:20 am by severdhed »
Caparo8bit
  • Hyperspin/Maximus
« Reply #6 on: September 04, 2013, 05:21:55 pm »
home button is to exit emulator to emulator menu / maximus arcade (esc. only exit rom)
HanoiBoi
« Reply #7 on: September 05, 2013, 06:49:36 am »
I don't quite understand the touchpad thing.  Does it do more than just control music?  It seems odd to me to be included on the CP.
Do you have a coin door?  If not, you might want coin buttons.
Are you locked in to the size and shape of the CP?  As mentioned, its a lot of real estate for what you need for controls.  You could probably clip the CP width by 8-12 inches.
Also as mentioned...the power button.  I'd suggest moving that off the CP altogether.  If not, kids will push it on purpose, adults will push it by accident.
BTW, is this a pedestal build?
« Last Edit: September 05, 2013, 06:51:27 am by HanoiBoi »
Caparo8bit
  • Hyperspin/Maximus
« Reply #8 on: September 05, 2013, 05:07:19 pm »
touchpad works as a mouse and kboard. main use to control musicbee and i have a showcase comes in two parts working on pedestal right now check my pictures below.oooh and for de coins or credits i hacked the coin ejectors
Caparo8bit
  • Hyperspin/Maximus
« Reply #9 on: September 05, 2013, 05:14:37 pm »
home  takes to emu menu    esc exit rom and  still on same emu.  (maximus arcade)
