Main > Software Forum
FE with custom categories?
Rick Sigouin:
--- Quote ---For a dos fe, GameLauncher will let you set up virtual emulators.
Dan:
I used SortInfo to separate my ROMs into directories corresponding to my CP's. Then I made a batch file with a menu for selecting the current CP. The batch file copies over the emuwizard.ini file associated with the CP. Then I just launch EmuWizard!
Dan
Lilwolf:
The you should appreciate this. I don't use a database, I wrote one for the frontend. by the time I finished all the features, I had a decent little database going that use vectors for indexs and hashtables for data.
But I would change in an instant to a true database because it gives you a TON of features, it's faster then anything you will write for a frontend, and it would help my memory requirements since I load all data into memory.
--- Quote ---
Ah databases are for sissies!
)p(:
--- Quote ---The you should appreciate this.
ArcadeFX:
Database all the way! Why load data that you are not gonig to ever uses. I only pull the data into AFX that is need, when it is needed. Database access even with Access is lightening fast. You can beat the power and speed of a db IMO.
