Main > Main Forum
Question Regarding Getting trackball to work
PL1:
Good news on the system recognizing the Opti-Pac. :woot
Try deselecting "Active High" and see if your windows cursor moves when you move the t-ball on the X-axis. (most trackballs are "active low" devices)
Yourname942:
I deselected the P1 Trackball checkmark, but it still doesn't move :-\
Is the optipac software utility supposed to show Send as greyed out and "no device" in red?
PL1:
If the Send option is grayed out and the software doesn't recognize the board, it couldn't command the Opti-Pac to switch between Active Low and Active High.
Sounds like you may need to e-mail Andy on this one.
Yourname942:
yeah, I sent him an e-mail, I hope its not a faulty Optipac :S
PL1:
While you are waiting, you can connect yellow to Y1, small green to Y2, and large green wire to frame ground.
