Author Topic: Question Regarding Getting trackball to work  (Read 1224 times)
Yourname942
  • Last login:October 01, 2016, 08:10:20 pm
« on: August 21, 2013, 01:25:01 pm »
Does anyone know how to get the trackball to work on the computer at all?
I am using: trackball + optipac
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=74&products_id=363
and
http://www.ultimarc.com/optipac1.html
The optipac led is green when plugged into the usb port of the computer, and the trackball is wired correctly, however the trackball currently does not function (ie. doesn't move the mouse cursor at all) Does anyone know how to get it to work? Thank you.
  • Last login:Today at 12:28:31 pm
Re: Question Regarding Getting trackball to work
« Reply #1 on: August 21, 2013, 02:54:17 pm »
Might be a good idea to post pics of the wire connections, just to be sure.
Are both LEDs per axis working? (use a digital camera / cel phone to look at the c-shaped optical circuits that the encoder wheel passes through)
Does the voltage on each data line vary when the encoder wheel is turned just far enough to block/allow the LED light to hit the optical receiver?
Are the data lines properly paired?
Green usually goes with yellow on one axis.
Blue usually goes with purple on the other.
RandyT
  • Last login:Yesterday at 12:12:44 pm
    • GroovyGameGear.com
« Reply #2 on: August 22, 2013, 03:40:06 pm »
The description for interface you are using notes this; "Configurable via software utility for active high/active low."  Have you checked this setting?
Also, be sure that the red and black wires are connected to +5v and Ground respectively, and not the other way around.  No function at all seems to indicate no power (or reversed power polarity) or incompatible sensor polarity.
Yourname942
« Reply #3 on: August 24, 2013, 12:12:43 pm »
where do you download that software utility? I cant find out where to get it.
Edit:
I downloaded it on my computer (Windows 7) and extracted it. It works perfectly, however when I move the extracted files to the arcade computer (windows xp) it gives me this error:
"The application failed to initialize properly (0xc0000135). Click on Ok to terminate the application."
Does this software not work on windows xp? will it not work if you just copy paste the 2 extracted files to the computer? I really need some help. (i can't get paid till i figure this out) :/
« Last Edit: August 24, 2013, 12:26:15 pm by Yourname942 »
« Reply #4 on: August 24, 2013, 01:00:46 pm »
That is a .NET framework error.
Not sure which version it needs, but you can get ver. 1.1 from Microsoft's servers here.
If that doesn't work, plug "Microsoft .NET Framework Redistributable Package" into the search bar at the top of that page for other options.
Yourname942
« Reply #5 on: August 24, 2013, 01:09:08 pm »
i installed that net framework now when I try to open the optipac software utility this error message appears:
"To run this application, you first must install one of the following versions of the .Net Framework:
V2.0.50727 Contact your application publisher for instructions of obtaining the appropriate version of the .Net Framework."
Do you know where to find that version?
Edit: I got it to work now, nvm, Thank you for the help, I never would of thought of that.
« Last Edit: August 24, 2013, 01:23:17 pm by Yourname942 »
ark_ader
  • I glow in the dark.
« Reply #6 on: August 24, 2013, 01:21:48 pm »
Www.oldversion.com
Has all the older .net packages.
« Reply #7 on: August 24, 2013, 01:24:43 pm »
The version it is asking for is here.
Install instructions also warn
IMPORTANT: After installing the .NET Framework 2.0 SP2 update you should immediately install the update KB959209 to address a set of known application compatibility issues.
Please note that KB959209 contains updates for several operating systems and architectures so you should be careful to only download and install the 2.0 Service Pack 2 update corresponding to your platform.
Yourname942
« Reply #8 on: August 24, 2013, 01:59:51 pm »
here is my setting atm:
and
2 questions:
Is the wiring wrong?
Is the settings wrong in the Optipac Software Utility?
« Last Edit: August 24, 2013, 02:01:46 pm by Yourname942 »
« Reply #9 on: August 24, 2013, 02:27:00 pm »
Looks like you have either frame ground (bleeds off static electricity charges) or the green Y-axis data line attached to the ground for Y-axis.
Try disconnecting all the Y-axis wires and moving the red 5v over to P1 Tball X-axis 5v. (4 spots to the right of current location)
Once you get X-axis working, add the data lines for Y-axis.
Once you have X- and Y-axis working, attach frame ground to dissipate static.
« Last Edit: August 24, 2013, 02:30:39 pm by PL1 »
Yourname942
« Reply #10 on: August 24, 2013, 02:33:42 pm »
I'm a little confused about the wiring you are suggesting.
Yourname942
« Reply #11 on: August 24, 2013, 02:48:44 pm »
here are a few more pictures for a clearer image of my current wiring:
here are the wires from the NorthEast side of the trackball:
and here is the thicker ground wire I think:
Is this correct?
« Last Edit: August 24, 2013, 03:40:01 pm by Yourname942 »
« Reply #12 on: August 24, 2013, 02:49:24 pm »
1. Move the red wire 4 places to the right.
2. Disconnect the yellow and two green wires.
3. Boot system up to see if the X-axis is working.
4. If x-axis isn't working, change the P1 Trackball setting in the software.
Once you get X-axis working, we'll work on Y-axis.
« Reply #13 on: August 24, 2013, 03:02:00 pm »
Is this correct?
The Green wire in the upper right isn't attached to the opto boards (red board lower left), so it appears to be the "Frame Ground" that I referenced earlier for dissipating static charges.
« Last Edit: August 24, 2013, 03:04:33 pm by PL1 »
Yourname942
« Reply #14 on: August 24, 2013, 03:36:53 pm »
I moved the red to the x axis +5 and took out the greens + yellow, opened the optipac software utility but it still doesn't do anything.
Edit:
and
here are the wires from the SouthWest side of the trackball:
« Last Edit: August 24, 2013, 03:43:06 pm by Yourname942 »
« Reply #15 on: August 24, 2013, 03:42:14 pm »
Are you on the right PS/2 connector?  Not sure which is correct.
Have you tried the mini USB connection?
Yourname942
« Reply #16 on: August 24, 2013, 03:50:37 pm »
yes I am on the right connection, but no I havent tried the mini usb yet.
What do I do with the rest of the wires now?:
the yellow, sea green, and mixed green(the larger wire not connected to the opto boards)?
« Reply #17 on: August 24, 2013, 04:13:33 pm »
The wires look correct. (We'll take care of the rest once the system recognizes the Opti-Pac and X-axis is working.)
Does the system recognize the Opti-Pac as a mouse? (Check under "Control Panel")
There may be a motherboard setting that disables the PS/2 ports.  :dunno
Do you have a Mini-USB cable available?
Yourname942
« Reply #18 on: August 24, 2013, 04:21:24 pm »
yes it shows up as 3 mice in the control panel:
its too close to the Ipac to fit into that slot :/
« Last Edit: August 24, 2013, 04:26:28 pm by Yourname942 »
Yourname942
« Reply #19 on: August 24, 2013, 04:37:13 pm »
does anyone know the wiring for this?
« Reply #20 on: August 24, 2013, 04:39:22 pm »
Good news on the system recognizing the Opti-Pac. :woot
Try deselecting "Active High" and see if your windows cursor moves when you move the t-ball on the X-axis.  (most trackballs are "active low" devices)
Yourname942
« Reply #21 on: August 24, 2013, 04:45:40 pm »
I deselected the P1 Trackball checkmark, but it still doesn't move  :-\
Is the optipac software utility supposed to show Send as greyed out and "no device" in red?
« Last Edit: August 24, 2013, 04:50:20 pm by Yourname942 »
« Reply #22 on: August 24, 2013, 05:04:38 pm »
If the Send option is grayed out and the software doesn't recognize the board, it couldn't command the Opti-Pac to switch between Active Low and Active High.
Sounds like you may need to e-mail Andy on this one.
Yourname942
« Reply #23 on: August 24, 2013, 06:03:27 pm »
yeah, I sent him an e-mail, I hope its not a faulty Optipac :S
« Reply #24 on: August 24, 2013, 06:14:10 pm »
While you are waiting, you can connect yellow to Y1, small green to Y2, and large green wire to frame ground.
