Author Topic: marquee light  (Read 3031 times)
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
marquee light
« on: August 18, 2013, 03:17:57 am »
ne ideas how to make the light even was thinking add some foil paper on the back......  :-\
kiwasabi
  • Last login:September 28, 2014, 12:14:51 pm
Re: marquee light
« Reply #1 on: August 18, 2013, 03:21:52 am »
Move it back as far as possible. Also, can't believe you're not using LEDs.
  • Last login:Today at 12:28:31 pm
Re: marquee light
« Reply #2 on: August 18, 2013, 03:36:34 am »
Foil will help some by reflecting more light.
You'll probably also want a diffusion layer of some sort.
Caparo8bit
  • Hyperspin/Maximus
Re: marquee light
« Reply #3 on: August 18, 2013, 03:41:40 am »
diffusion layer  ???""" ya mean somthing between light and sign?
Re: marquee light
« Reply #4 on: August 18, 2013, 03:55:41 am »
Yes, something that scatters the light like this but thinner.
LED buttons use them too -- red disc to the right of the white plunger.
Caparo8bit
  • Hyperspin/Maximus
Re: marquee light
« Reply #5 on: August 18, 2013, 02:07:29 pm »
Thanks will post results
Caparo8bit
  • Hyperspin/Maximus
Re: marquee light
« Reply #6 on: August 18, 2013, 02:11:56 pm »
LED will b nice but I'm not good finding the right voltage for stuuf already burn a 12v fan and two fingers by holding the Soldering iron thingy from the wrong side  :angry:
  • Last login:April 27, 2024, 06:07:53 pm
Re: marquee light
« Reply #7 on: August 18, 2013, 03:20:28 pm »
its easy to find 12v. You can tap the yellow on a molex connector use use the 12v from your arcade power supply. Also, the animated Caparo in your sig is super annoying, congrats!
  • Last login:October 20, 2023, 11:39:06 pm
Re: marquee light
« Reply #8 on: August 18, 2013, 04:19:52 pm »
Having multiple light bars will help disperse the light better.  My suggestion is to remove the florescent light completely (including the square thing on the bottom (ballast) which will create a shadow on your marquee).  Replace it with this (under $10 with free shipping):  http://www.ebay.com/itm/LOGISYS-WHITE-12-DUAL-COLD-CATHODE-LIGHT-KIT-PC-Computer-CCFL-Inverter-Switch-/380401847045?pt=US_Computer_Case_Accessories_Tool_Kits&hash=item5891b78b05
Put one on the top and one on the bottom and you will be all set.  The kit comes with 2 light bars and plugs right into a 12v molex connector on your power supply.
Good Luck!
DeLuSioNaL29
« Last Edit: August 18, 2013, 04:21:59 pm by DeLuSioNal29 »
UFO
  • Last login:July 22, 2022, 06:37:12 pm
  • Im nearly out of unproductive things to do at work
Re: marquee light
« Reply #9 on: August 18, 2013, 04:30:01 pm »
From what I can see, I would also try and centre it vertically...
Caparo8bit
  • Hyperspin/Maximus
Re: marquee light
« Reply #10 on: August 18, 2013, 07:21:03 pm »
ima try this
« Last Edit: August 18, 2013, 07:26:13 pm by Caparo8bit »
marquee light
« Reply #11 on: August 18, 2013, 08:06:22 pm »
Sounds expensive...  My solution costs under $10 and has worked for me for several cabs.
D
BobA
  • What Me Worry?
Re: marquee light
« Reply #12 on: August 18, 2013, 08:28:07 pm »
He already has the florescent light going to why not just diffuse the light with something behind the marquee like bit of translucent plastic panel or even white paper.  The spot can also be reduced by covering the sides and back of the marquee light area with crinkled tinfoil that will help scatter the light.  I use metal aluminum tape on the inside of the marquee area.   It is real tape for ducts not the plastic duct tape that people buy that does not stick and does almost no good.
« Last Edit: August 18, 2013, 08:29:48 pm by BobA »
severdhed
  • RIP Dinosaur Hippo
Re: marquee light
« Reply #13 on: August 18, 2013, 09:35:30 pm »
you need to diffuse it, perhaps take a sander to a piece of plexiglass and place it between the light and the graphic?
Caparo8bit
  • Hyperspin/Maximus
Re: marquee light
« Reply #14 on: August 18, 2013, 10:35:27 pm »
 :banghead: read post replys to late already ordered
Caparo8bit
  • Hyperspin/Maximus
Re: marquee light
« Reply #15 on: August 18, 2013, 10:39:09 pm »
lol annoying in a good way or the other way... :P
CoryBee
  • Last login:October 21, 2023, 07:12:25 pm
  • Bopity Boopy
Re: marquee light
« Reply #16 on: August 18, 2013, 10:45:41 pm »
I agree. Annoying. Make it stop!
Also, I always hated that floating mouse thing to try and trick me. Lose that too, please.
Thanks for posting those DeLuSioNal29, I am going to go with those from now on. Cheers!
Caparo8bit
  • Hyperspin/Maximus
Re: marquee light
« Reply #17 on: August 18, 2013, 10:47:45 pm »
ok  :blah:
Caparo8bit
  • Hyperspin/Maximus
Re: marquee light
« Reply #18 on: August 18, 2013, 11:33:14 pm »
good tip i think even whit this LED i need a deffusing. soonest i get LED i will post the results ... thanks all for your help :cheers:
Connorsdad
  • Last login:December 22, 2018, 05:56:03 pm
Re: marquee light
« Reply #19 on: August 19, 2013, 03:44:22 am »
You can use a piece of "satin" or "sandblast" glass as a diffuser. I have a piece of 4mm clear glass and a piece of 4mm satin glass with my marquee artwork trapped in the middle, works brilliantly :)
Sent from Amstrad CPC464
epetti
  • Last login:September 14, 2023, 10:15:20 pm
marquee light
« Reply #20 on: August 19, 2013, 10:04:42 am »
I found that just painting all four sides around the light white without any diffuser was enough in my case.
Caparo8bit
  • Hyperspin/Maximus
Re: marquee light
« Reply #21 on: August 23, 2013, 08:11:52 pm »
jus bought this for my marquee to diffuse the light and still waiting for LEDs
Unstupid
Re: marquee light
« Reply #22 on: August 23, 2013, 09:03:27 pm »
That'll work... now ditch the LED's and just use the fluorescent bulb that tis in there already!
Caparo8bit
  • Hyperspin/Maximus
Re: marquee light
« Reply #23 on: August 23, 2013, 11:17:53 pm »
  ;D already pay for LED's and cant return........  btw  with LED's ima b able to change colors on my marquee :applaud:
Caparo8bit
  • Hyperspin/Maximus
Re: marquee light almost
« Reply #24 on: August 26, 2013, 10:39:50 pm »
testing LED's can change to many colors the problem is tha i painted the logo blue now have to make it clear  :applaud:
[imghttp://i.imgur.com/Q06RodY.jpg]http://[/img]
