Author Topic: Begging for help with sega model 2 emulator  (Read 3664 times)
Franco 38
  • Last login:September 11, 2013, 12:01:29 am
« on: August 14, 2013, 08:46:35 am »
Guys, i need this to work, i have nebula 1.0 but when i load the roms the cpomputer says it found an error and cannot open it. What can i do???
  • Last login:May 05, 2024, 08:59:50 am
Re: Begging for help with sega model 2 emulator
« Reply #1 on: August 14, 2013, 08:49:35 am »
Could you be more specific?
Franco 38
« Reply #2 on: August 14, 2013, 09:36:04 am »
Thank you so much for replying.
I have a hp pavillion g6. I install the emulator and when i click on the file i see the amd opening screen, fine. Once i click on load games and pick from the list, and the screen gets fadded and i get a box sayin" a problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available".
I even downloaded directx 9 and the visual +++ , just not sure the right one.
Buddy, i beg for your help, i want this so bad, its not even funny, and i think the pavvilion g6 bought in 2011 is powerfull enough. I stayed almost all night trying this so, i would thank you from the bottom of my heart for helping. Please let me know any questions you have, and thanks again for working with me.
Endprodukt
  • Last login:November 14, 2023, 12:54:43 pm
AW: Begging for help with sega model 2 emulator
« Reply #3 on: August 14, 2013, 09:40:03 am »
Try launching a game from the command line and see if it works.
« Reply #4 on: August 14, 2013, 09:46:10 am »
It might be that your video card or built-in video does not support pixel shader 2.
If so, there's nothing you can do about it except get a newer video card.
Almost everything you wanted to know about Model 2 Emulator can be found here:
http://forum.arcadecontrols.com/index.php/topic,131527.0.html
*Requires Pixel Shader 2.0 compliance for proper emulation.  Minimum cards are as follows:
ATi:Radeon 9500 or newer. nVidia:GeForce FX series, 6 series, or newer.
« Last Edit: August 14, 2013, 09:49:08 am by BadMouth »
Franco 38
« Reply #5 on: August 14, 2013, 09:53:34 am »
Thanks buddy. I have a hp pavillion g6, graphics card is amd radeon hd 6480g
Is that good or bad news?
Franco 38
« Reply #6 on: August 14, 2013, 10:15:22 am »
I am sorry for being so ignorant with this, but does that mean i need a better video card? Honestly if thats the case i wold even be relieved for a while, since i kniw its just a matter of buying a better video card. Please guys let me know and i leave you alone. But again, every single help from you all is much appreciated, !
« Reply #7 on: August 14, 2013, 10:15:50 am »
Quick google search says it supports 5.0, so you're good there.
Before launching a game, make sure autofullscreen isn't checked.
Sometimes the graphics settings will make it crash in fullscreen, but it will be ok windowed.
If it works windowed, then you've narrowed it down a bit more.
For good measure, install both runtimes listed on this page:
http://code.google.com/p/nulldc/
Franco 38
« Reply #8 on: August 14, 2013, 10:23:42 am »
I am on windowed mode so iam not full screen. Onçe i load the game it just goes to the windows message "emulator_multicpu.exe has stopped working" and i have to close it. When i installed i got a message saying that a script file could not be encrypted, or something like that. I just dont know what to do , i am getting so close, once i saw the amd screen i got happy but then this. I want this to work so much!!
Franco 38
« Reply #9 on: August 14, 2013, 10:40:49 am »
Oh my god man it works! Bad mouth god bless you for the rest of your life! I just got house of dead to try, and it loads man, i am almost crying. I am gonna hook it up to the tv with a 360 controller, is the controler set up pretty simple? I think i saw in the options that you can just select the 360 controller right away. Does the ps3 controller works? I am gonna get drunk to celebrate and try to get a few games, and i will be back later. Thank you to everybody that replied to me, no words to express my gratitude , !!!!!
« Reply #10 on: August 14, 2013, 10:43:57 am »
Controllers don't work with the gun games, at least not easily.
Use the mouse.
Controllers can be made to work in the gun games with Troubleshooter 2,
http://forum.arcadecontrols.com/index.php/topic,130784.msg1339402.html#msg1339402
but you should get to know your way around the emulator before moving onto that.
The controller will work fine with all the other games.
Franco 38
« Reply #11 on: August 14, 2013, 10:47:10 am »
Absolutely, i am happing just to stare at the intros of these games , i can just stare the whole day man. Butneventually, i think , and i do not mind, you have to run the game, and then inside the game go to some options and change it right? But i did get to play house of dead what a feeling. Without abusing your kindness, any quick tips to improve the image? Iam gonna take my time learning about the emulator, no rush!!
« Reply #12 on: August 14, 2013, 10:59:22 am »
To remap the controls, run the game windowed and click on the game tab, then configure controls.
There is nothing that I can tell you that isn't already covered in the Model 2 setup guide linked to earlier.
Franco 38
« Reply #13 on: August 14, 2013, 11:52:20 am »
Thanks man for the links but you are helping me so much, that im overwhelmed. I thought i saw somewhere an option to activate the 360 controller but i cant find it now. Does the ps3 controller work as well?
  • Last login:April 27, 2024, 06:07:53 pm
« Reply #14 on: August 14, 2013, 11:58:11 am »
any controller will work if it works in windows.
You just open the button config screen and map the buttons.
Franco 38
« Reply #15 on: August 14, 2013, 01:00:44 pm »
Thank you agin to all. My last question, the graphics look a little pixalated, not as crispy as i see in videos, is there any graphical settings that i should change to look better? Increase resolution would work? Thank you all again!
