Main > Main Forum
Aimtrack MODEL2 Issues
Pages: << < (2/2)
BadMouth:
You shouldn't be using rawinput.
With it turned off, any mouse connected (including the aim-trak) will control the crosshairs.
Left click is fire, right click is reload.  Setup the aim-trak utility accordingly.
Get it working like that before moving onto Troubleshooter or you'll just be creating more possibilities for incorrect settings.
charlieram:
You need rawinput it you want more than one gun but I agree with badmouth, get the one gun working correctly before you try and get 2 working.
BadMouth:
--- Quote from: charlieram on August 13, 2013, 09:58:42 am ---You need rawinput it you want more than one gun but I agree with badmouth, get the one gun working correctly before you try and get 2 working.
He only mentioned one gun, so I assumed he only has one.  :P
charlieram:
And I assumed he had two guns because he was using Troubleshooter  :P back a ya  :cheers:
eidern:
(This is still coggia, i'm onto another computer and I see now that I've another registered account remebered on this computer)
Thanks for the replies,
So yes I've got just one lightgun and I use troubleshooter because i've seen there are reloading issues with theM2 emulator that can be corrected with troubleshooter, and this is troubleshooter that configured the ini this way.
But my problem is still the same even my rawinputdevice set to 0
Pages: << < (2/2)
Go to full version
