Main > Main Forum
LED BUTTONS
Caparo8bit:
--- Quote from: Malenko on August 18, 2013, 03:18:55 pm ---
--- Quote from: Caparo8bit on August 18, 2013, 02:19:24 pm --- :cheers: Thanks Boba I ordered 20 led buttons and 18 awg cable now need to find 12v from computer or arcade amp... Cross my fingers. :notworthy: btw can I ground LED with ground from button?
get a Molex (4 pin power 8189 series) splitter, put it in your computer, tap the yellow for 12v and the black for ground. Dont wire in the grounds with the buttons, its usually best for beginners to keep wiring sets isolated from one another.
got ya ...my control panel is litle far since i have the showcase and i have to run the 12v and ground from pc to control panel 1 line of each will b enough for all buttons i just splice from one to other i think they calle that daysi somthing daisy duck????
Malenko:
Daisy Chain.
You can run 2 wires (+12v and ground) from your power supply to your control panel, then splice/chain from there
PL1:
--- Quote from: Malenko on August 19, 2013, 09:00:43 am ---Daisy Chain.
Not to be confused with Daisy Duck . . .
. . . or Daisy Duke.
Caparo8bit:
:laugh2: " DAISY CHAIN" hey running one 12v per player will make diference on brightness?
Malenko:
not likely.
