Author Topic: What are those plastic things that clip on NO and GND button contacts called?  (Read 1886 times)
marioxb
  • Last login:March 08, 2024, 01:54:31 pm
And where can I get em? My cabinet has the wires soldered onto the joystick and button contacts and I want to replace them with the slip on contact thingies. Does radio shack have them? I also want a wire that has like 8 to 10 of them in a line to ground all of the buttons and joysticks with one wire. Where can I find one of those?
CoryBee
  • Last login:October 21, 2023, 07:12:25 pm
  • Bopity Boopy
They are called quick disconnects or QDs.
Edit: You are looking for .187" ones for standard arcade buttons
Edit: Edit: In before PL1 brings his fury of research and articles pertaining to every version of QD
« Last Edit: August 11, 2013, 05:53:41 pm by CoryBee »
Caparo8bit
  • Last login:April 28, 2018, 02:13:32 am
  • Hyperspin/Maximus
dont go to Radio Shack they sell high 10 for $3.00 im looking for the web the sells cheap hang on
« Last Edit: August 12, 2013, 12:27:34 am by Caparo8bit »
CoryBee
  • Bopity Boopy
100 pieces for just under $5
Red
Blue
Caparo8bit
  • Hyperspin/Maximus
  • Last login:April 28, 2024, 12:59:28 pm
I forgot here who posted it, but in the future I'm going to buy a cheapie JAMMA harness and cut the wires off for my own uses. I did that recently, and it was like a godsend. Everything's already crimped, you get a daisy-chained ground wire, and it's about $15 shipped.  :cheers:
 :laugh2:
CoryBee
  • Bopity Boopy
 :laugh2:
  • Last login:Today at 12:28:31 pm
Another option is to get pre-crimped 1 meter wires (available in a variety of colors with .110", .187", or .250" QDs) and prefab daisy chains (red or black with .110", .187", or .250" QDs) from Paradise Arcade Shop.   ;D
No need, you answered OP's question clearly and concisely -- wouldn't make sense to introduce spade terminals, flag terminals, bullet terminals, D-Subs, RJ-45s, Molex KK-100s, . . . .  :duckhunt
jdbailey1206
 :laugh2:
Hey!  That pup bit my finger!  Which, of course leads me to
marioxb
Thanks guys! i will check all of those options out!
So, at Paradise Arcade, I assume this is what I am looking for, as far as the ground wires? 30 Connection Black Daisy Chain (.187")
I will probably get that as well as quick disconnects for the non-ground wires. And .187 is the standard size?
« Last Edit: August 13, 2013, 06:26:51 pm by marioxb »
Looks good.
.187" is the standard size for most arcade microswitches.
Some microswitches use .250".  (I got a batch of IL's from Andy with this type once.)
Goldleaf, Sanwa, Seimitsu, and leaf switches use .110".
ark_ader
  • I glow in the dark.
Spade connectors
Caparo8bit
  • Hyperspin/Maximus
Looks good.
if I'm right .250 is for LED
Too bad the wiki broke, I was never able to finish this: http://wiki.arcadecontrols.com/wiki/Wiring
ppv
  • Last login:October 16, 2020, 03:08:56 pm
  • The cheap@ss gamer
Sorry wrong thread.
Doing arcades, the cheap@ss way!
First Project : ttp://forum.arcadecontrols.com/index.php/topic,151071.0.html
Next one : The Token Muncher [urlhttp://forum.arcadecontrols.com/index.php/topic,135417.0.html[/url]
camconcay
  • Last login:September 23, 2013, 12:48:17 pm
or http://www.ebay.com/itm/WIRE-KIT-MAME-Arcade-Game-Crimps-control-panel-push-button-joystick-stranded-/160942758736
I purchased this set and received it next day - excellent service and just as described - no affiliation just wanted to pass on what looks to be a good deal and great ebay service
Caparo8bit
  • Hyperspin/Maximus
this is what i got for $20  100 ft of 18 awg cable (2 colors)  .250 quick disconnect (qty 100) and .187 quick disconnect (qty 100 )
